Awd79 31 #1 Posted September 10, 2025 Mysteriously started backfiring. I noticed some fuel as well around the fuel pump and hose clamps missing or have slid down. This machine I got a month ago and was running well. Could the fuel pump be causing the issue? I assume I need to pull the head and check the valves? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,998 #2 Posted September 10, 2025 Have another condenser you could try or temporarily remove it and give it a try. They can do weird things when they start to fail. 3 1 Share this post Link to post Share on other sites
953 nut 64,108 #3 Posted September 10, 2025 If an engine idles well, but runs erratically when revved up, like it hits and misses, pops and backfires, then chances are, it needs a new condenser/capacitor. And always install a condenser/capacitor with the wire facing downward so rain water and/or when washing off engine, water will not enter inside condenser/capacitor, ruining it. With water inside the condenser, this will also allow it to idle well, but cause it to run erratically when revved up. 4 1 Share this post Link to post Share on other sites
Awd79 31 #4 Posted September 11, 2025 It runs on choke and at low idle. At high idle it pops and fires and just sounds like my unruly teenager. The guy I point it from didn’t points and condenser but no idea if he did it correctly. I have points and condenser for a raider 14 I haven’t tore into yet. I assume they are the same but will check. 1 Share this post Link to post Share on other sites
Awd79 31 #5 Posted September 11, 2025 Thank you everyone Share this post Link to post Share on other sites
Awd79 31 #6 Posted September 11, 2025 2 hours ago, 953 nut said: If an engine idles well, but runs erratically when revved up, like it hits and misses, pops and backfires, then chances are, it needs a new condenser/capacitor. And always install a condenser/capacitor with the wire facing downward so rain water and/or when washing off engine, water will not enter inside condenser/capacitor, ruining it. With water inside the condenser, this will also allow it to idle well, but cause it to run erratically when revved up. what if the new owner power washed it. 🤣 this is making more sense to me now. if I get into it and there is water is it fouled or salvageable. If I recall the part is not spendy. 2 Share this post Link to post Share on other sites
953 nut 64,108 #7 Posted September 11, 2025 11 hours ago, Awd79 said: if I get into it and there is water is it fouled or salvageable. If I recall the part is not spendy. Once water has gotten into a condenser it is junk. I am presuming that your Wheel Horse C-105 has the Kohler K241AS engine as it left the factory with. If this is the case the condenser is Kohler part # 230722 and should be easily found at any small engine parts supplier. Share this post Link to post Share on other sites
lynnmor 8,623 #8 Posted September 11, 2025 11 hours ago, Awd79 said: It runs on choke and at low idle. At high idle it pops and fires and just sounds like my unruly teenager. Pull the carburetor and clean it properly. If it is adjustable, follow the manual. Share this post Link to post Share on other sites
