mattg
414-8 exhaust valve sticking?
mattg
Good Morning, Hope everyone is enjoying the holiday!
So i have a 414-8 with the magnum kohler, thing ran flawlessly until a few weeks ago. It started to have a misfire and i noticed when i hold hand in front of exhaust it does not have the normal pressure, so i assumed the exhaust valve was sticking. I removed the cover plate and turned engine over by hand and it appeared that they both seemed to move. I did go in there and work them with a screwdriver and they seem to snap ok. Before I dig into it any farther any suggestions?
have a good day!
gwest_ca
Try it with the muffler removed.
ri702bill
And perform a cylinder leak-down test. Air coming out of the exhaust when both valves are closed confirms it.
How long since the last head removal and de-carboning??? A stray chunk of carbon when stuck between the valve & its seat will act the same way.....
Edited by ri702bill
peter lena
@mattg  , been using this for years now  , rislone  zinc  zddp  additive ,  add 4 oz   to every oil change , the cleaning  factor alone , is worth its use , its the  very smooth  running  that you can sense , also the hot oil changes are  very black oil  and flushing , is showing you the varnish removal ,  another thing  is the elimination  of frequent , starting smoke . realise this is a  touchy issue ,  but I experiment with  any issue , and improve the original   failure point ,  no smokey starts , easy running  .  couple hrs  , of hot  varnish break down , would not hurt  . pete
wallfish
The internals of the muffler rust and rot which can come loose and block the air flow.
mattg
Hello,
Haven't ever had had head off to clean, just oil changes every season for the last 20yrs. I did try some marvel mystery oil, no luck. I will put valve cover back on, need a new gasket now, any chance someone has the part # for that?. then I will check the muffler and head and maybe try the suggested additive see what happens. Thank you for all the suggestions, greatly appreciated!
Matt
Sparky
  Exact same issue I had with a Magnum 14. Turned out part of the baffle inside the muffler had rotted or broke off and would get itself in front of the muffler output.
  Real easy to remove, then shake it, you’ll know if there’s a loose piece inside right away.
8ntruck
Just opinion here.  Additives are not a sure fire fix.  Sometimes they help, other times, they don't.
Whatever issue you have, it took some time to develop.  With this in mind, it will likely take an additive some time to work.
Good luck.
mattg
Thank you! Going to remove muffler, hopefully today
mattg
Hello,
Sorry for the delay in an update. It was defiantly the muffler causing my problem. Now, what type of muffler do I want to replace it with, I know the originals are obsolete. I'm thinking a stack muffler with a tapper on top. Had a gt-14 one time with one on, kinda cool. Thoughts?
