clueless 3,439 #1 Posted August 31, 2025 Will the 6 inch wheel front spindles work on a C series and vice versa? Share this post Link to post Share on other sites
ebinmaine 80,657 #2 Posted August 31, 2025 Absolutely. The 6 inch spindle is an inch taller than the 8 inch spindle. I use them on my woods tractors for extra ground clearance. If you use a 6 inch spindle and mower... be aware that you may have fore/aft deck line-up issues due to the height difference. 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,270 #3 Posted August 31, 2025 I swapped the 6" for 8" wheels on my 310 and 312. I kept the taller 6" spindles to get more clearance under the front axle for more lift on the snow plow and the front plow frame mounted tiller. I have a 42" SD on the 310 and a 48" SD on the 312 and had no problem leveling the for/aft decks. 3 Share this post Link to post Share on other sites
Lee1977 7,768 #4 Posted September 1, 2025 Here is a picture of a 312-8 with 8" wheels on the 6" spindle. Mower deck still works just need to adjust the rod. 3 Share this post Link to post Share on other sites
Ed Kennell 47,270 #5 Posted September 1, 2025 Same set up on my 310 and 312. 2 Share this post Link to post Share on other sites
