Gary S Minnesota 59 #1 Posted August 24 Hi All, I seem to be having drive belt issues with the 1977 C-160 I recently acquired. In way of background I changed oil, hydro oil and filter and did a general clean up. Everything seemed fine until I mounted a 48” SD deck and started mowing. The tractor seemed to be struggling a bit going through not real long grass, although the height adjustment was set lower than I usually use on my 314-8. Before long I could smell burning belt so I headed for the garage. I removed the seat etc. and finally the belt guard and discovered belt shavings in the area around the idler pulley. The idler pulley appeared to run free with no wobble or noise. Inspecting further I noticed a cut across the width of the 5/8 x 84” drive belt. I then installed a new drive belt. After installing the new belt I noticed a lot of noise and vibration coming from the belt guard area when lifting the deck to max height with the hydro lift. The lift runs smooth and quite until the max up position? Pretty soon I smelled burning belt again. I again removed the belt guard and noted that the inside edge of the idler pulley was actually sitting atop the inside edge of the new belt and had actually cut the inside edge of the new belt. It appears that the idler pull is not in straight alignment with the PTO pulley or Sundstrand hydro pulley. Is it possible to move the PTO pulley outward 1/8” or so, or move the hydro pulley in an 1/8” ? I’m also wondering if the idler pulley/parking brake linkage may be worn or slightly bent. Pulling that lever up or pushing it back down takes quite a bit of effort. Like the spring is stronger than need be?? Appreciate any input. Apologies for the long post! Gary Share this post Link to post Share on other sites
Ed Kennell 42,481 #2 Posted August 24 7 hours ago, Gary S Minnesota said: I’m also wondering if the idler pulley/parking brake linkage may be worn or slightly bent. This worn linkage is likely the problem. The pulley bearing may also be worn out. 1 Share this post Link to post Share on other sites
pfrederi 18,810 #3 Posted August 24 Use a long straight edge to make sure the Engine pulley idler and Pump pullies are all aligned. You can move the engine and Pump pulleys in and out a bit. Share this post Link to post Share on other sites
peter lena 9,348 #4 Posted August 24 @Gary S Minnesota that related bouncing is telling me , INCREMENTAL BEARING HANG UP , usually bearing lubrication , failure . done a lot of decks , amazing how many MOVEMENT POINTS , have a bind or rough spot . thats the start of belt bounce , related , buzzing go over every movement point , those idler pulleys with those tiny , sealed bearings , are a main culprit , tiny bearing with unknown lubricant , is a very fast failure , might consider getting a similar pulley , with a larger bearing and removable wide side grease shields , done that with bushing added to larger bearing, and cleaned out original grease , replace with hi temp lucas chassis grease , no noise or failures , original set up is marginal at best . have also added an idler pulley on back side of long UNSUPPORTED , spindle belt , really controlled that belt bounce . pete Share this post Link to post Share on other sites
Gary S Minnesota 59 #5 Posted August 31 Well I finally got over to Wheel Horse Parts and More at Medford, Mn. and met Lowell. He had the drive belt idler pulley i wanted in stock and was very helpful in giving me a tips on aligning the Sunstrand pulley, the idler pulley and the PTO pulley. I needed to move the PTO pulley outward a good 1/4" to bring things into proper alignment. I'll install a new belt and reassemble the belt cover etc tomorrow. I'm pretty confident my belt slap and vibration I noticed when the hydro lift raises the deck to max height will be gone. Sure hope so! Thanks everyone for your comments and suggestions. You guys are great! 1 Share this post Link to post Share on other sites
