pmccall 0 #1 Posted August 24, 2025 New to the site Just bought a 1993 520h First wheel horse,front tires need tubes. Do i use straight or bent valve stem tubes? Thanks in advance Share this post Link to post Share on other sites
8ntruck 8,592 #2 Posted August 24, 2025 I use tubes with straight valve stems. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,992 #3 Posted August 24, 2025 Do some measuring before hand. I replaced 2 - 18x8.50-8 Carlisle tires with new same size tubes. Drove about 1000 feet and one went flat. Discovered the 18" tall tires are now 16" tall but the 18" tubes are still 18". You can't jamb an 18" tube in a 16" tire and expect it to last. Share this post Link to post Share on other sites
ri702bill 11,230 #4 Posted August 24, 2025 Upon reassembly, use talcum powder on the inside of the tire to allow the tube to wiggle itself into position when inflated... 1 1 Share this post Link to post Share on other sites
ri702bill 11,230 #5 Posted August 24, 2025 New tube from an offshore supplier?? Do not destroy the packaging - inflate the tube about 2 days before you plan to use it. You may be disappointed to find it deflates before you need it. Return it in the original package, try again. Guess how I know.... Old domestic made heavy walled tubes are the best. Share this post Link to post Share on other sites
Lee1977 7,550 #6 Posted August 24, 2025 I have had good luck with Firestone branded tubes made in Korea that I bought from a local tire store. Share this post Link to post Share on other sites
Lagersolut 793 #7 Posted August 24, 2025 (edited) On a side note I remember when tubes were a cheap fix - cheaper than a new tire but a far cry from the cheap they used to be - keep a few here for emergency - the jungle site has cheap tire bars for small tires broke in on the Troy Horse this year - highly recommended over my original pinch it and do it over with pry bars and screwdrivers method Edited August 24, 2025 by Lagersolut Share this post Link to post Share on other sites
