Ed Kennell
Old School Tools
Treepep
30 minutes ago, Ed Kennell said:
My el cheapo HF sander took a crap while sanding all those park bench boards.    So, I spotted this one at the auction this morning.  Plugged it in and it ran nice and quiet so I thought I might buy it if the price was right.     When they put it up, they sold it with this scroll saw that I did not need.
Both are USA made Craftsman Sears Roebuck/ Simpson MFG all metal  2.25 Amp.
The sander even has an oiler port.
The Scroller Saw is 1/2HP with variable speed and rotatable blade.
105_1351.JPG.6786fa7ebe3419650cdbb615cce72497.JPG105_1352.JPG.b41f9257240b9584f6875177f95727d7.JPG105_1353.JPG.8090897074bf650ce910cbcc99406598.JPG
These things are heavy at 8 and 10 lbs each.
   Oh, and the price was right at $2.00 + 12 cents tax for the pair.
And here I thought you were calling one of us out!:D
  • Haha 5
JoeM
I have the same scroll saw, it was my Dad's. The cord is all taped up where he cut into it.
I don't use it because the lock on top only locks in one direction. It is/was a very actuate saw. Top quality.
Got me thinking, not sure where I put. it? :eusa-think:
ri702bill
Check the condition of the brushes on the sander - they live in a very dusty environment..
The sander must be about 60+ years old.... the cord may be about done for....
Edited by ri702bill
Ed Kennell
This one locks in 4 positions at 90 degrees.
Bill D
Plan on changing the cord.  When you do, install a three wire cord and ground the metal case.  There is probably a screw inside the handle that can be used for this.  Also, plug tools like that into a GFCI outlet when using.
I had an old metal drill 30 years ago that I was nearly electrocuted by.  I am somewhat leary of old electric tools for that reason, though I appreciate the quality compared to modern tools.
Edited by Bill D
Ed Kennell
I opened them both today and checked the brushes and the cords.   The sander did need a cleaning, but the brushes and cords all look good.
The existing 3 wire cords and grounds  look good.
105_1361.JPG.42f1703972a7cd3cdc289e3e057cad42.JPG105_1360.JPG.e199a6eb57773f93dcbfa4c24173307e.JPG
  • Like 4
Wayne0
Nice score, Ed! I have my Father's Craftsman scroll saw as well as his belt sander. Heavy and durable!
I had Grand Dad's Craftsman Iron drill press for quite a while before replacing it with a 220vac unit from a machine shop.
The quality of newer tools is not what it used to be.
formariz
Good find Ed. They will last a few more generations if used. No plastic , disposable mentalities back then. Changing the cords is the only must do with them. Use a three prong and ground the case.
Ed Kennell
43 minutes ago, formariz said:
Changing the cords
I disassembled and cleaned both and surprisingly the original Craftsman  3 prong grounded cords and restraining grommets are like new..     Very pliable and no sign of cracking.
