Treepep 935 #26 Posted August 18 17 hours ago, FarmallFarmer09 said: And after i paint it, Should i clear coat it? And if i do clear coat it, What do i use? I plan on using good old rattle can paint job, And im getting all my paint from menards. That's a reference... I guess I thought Menards was regional. Must be all over??? 1 Share this post Link to post Share on other sites
AlexR 2,307 #27 Posted August 18 8 minutes ago, Treepep said: That's a reference... I guess I thought Menards was regional. Must be all over??? It is kind of regional it's mainly in the Midwest It's based in WI, but we have a lot of them here in Indiana. Share this post Link to post Share on other sites
Treepep 935 #28 Posted August 18 1 minute ago, AlexR said: It is kind of regional it's mainly in the Midwest It's based in WI, but we have a lot of them here in Indiana. Wild, I am originally from Nebraska. Menards is one of the big three. Preferred Menards. And tried to support the locals till they started selling mostly chinesium. Then I was out 1 Share this post Link to post Share on other sites
FarmallFarmer09 13 #29 Posted August 18 Out here just working some things out, Where can i get the choke and throttle nobs? And a hood latch nob, A rear light, And potentially a new steering wheel? Share this post Link to post Share on other sites
FarmallFarmer09 13 #30 Posted August 18 22 hours ago, TonyToro Jr. said: I would say probably 5 depending on how many coats you do How many coats should i do? Share this post Link to post Share on other sites
8ntruck 8,332 #32 Posted August 19 Several light coats are better than one heavy coat. Share this post Link to post Share on other sites
FarmallFarmer09 13 #33 Posted August 19 Okay. Now heres a question i keep forgetting about. I talked to a big guy in wheel horse at a show, because my fwd and reverse lever is super loose. It doesn't stay in one area, It will always go straight to full. Whats the plastic plate called so i can get an new one? Anyone know? (Its a 1971 Charger 12 if that helps) Share this post Link to post Share on other sites
Bar Nuthin 1,810 #34 Posted August 19 (edited) 10 hours ago, FarmallFarmer09 said: Okay. Now heres a question i keep forgetting about. I talked to a big guy in wheel horse at a show, because my fwd and reverse lever is super loose. It doesn't stay in one area, It will always go straight to full. Whats the plastic plate called so i can get an new one? Anyone know? (Its a 1971 Charger 12 if that helps) Are you talking about this piece (cam plate)? I got mine from Lowell (wheelhorsepartsandmore) but it looks like he is out of stock. BTW, that is the part number for my C-120, you need to look in your parts manual for the correct part number. Edited August 19 by Bar Nuthin Share this post Link to post Share on other sites
squonk 44,860 #35 Posted August 19 (edited) 10 hours ago, FarmallFarmer09 said: Okay. Now heres a question i keep forgetting about. I talked to a big guy in wheel horse at a show, because my fwd and reverse lever is super loose. It doesn't stay in one area, It will always go straight to full. Whats the plastic plate called so i can get an new one? Anyone know? (Its a 1971 Charger 12 if that helps) The plastic plate may not the problem. These screws may not be tight enough or the tension plates are warped /worn. I've had luck replacing the screws with allen head screws and adding a washer to increase spring pressure. Edited August 19 by squonk Share this post Link to post Share on other sites
Bar Nuthin 1,810 #36 Posted August 19 46 minutes ago, squonk said: The plastic plate may not the problem. These screws may not be tight enough or the tension plates are warped /worn. And you definitely do not want to lubricate the plate. Keep it clean. Share this post Link to post Share on other sites
FarmallFarmer09 13 #37 Posted August 19 Okay. Another few things, What would be the best material for sandblasting? Wallnut shells, Or Baking soda? And i called a guy, And he said that if you spray a coat of primer, You wont need as many cans of paint? Is this true? Thank you guys for all your help, I appreciate it a TON!!! Share this post Link to post Share on other sites
FarmallFarmer09 13 #38 Posted August 19 9 hours ago, squonk said: The plastic plate may not the problem. These screws may not be tight enough or the tension plates are warped /worn. I've had luck replacing the screws with allen head screws and adding a washer to increase spring pressure. Okay ill take a look at it. Share this post Link to post Share on other sites
FarmallFarmer09 13 #39 Posted August 19 3 minutes ago, FarmallFarmer09 said: Okay. Another few things, What would be the best material for sandblasting? Wallnut shells, Or Baking soda? And i called a guy, And he said that if you spray a coat of primer, You wont need as many cans of paint? Is this true? Thank you guys for all your help, I appreciate it a TON!!! And if anyone really knows, How many cans of primer should the full tractor take? rims too. Share this post Link to post Share on other sites
Retired Wrencher 6,168 #40 Posted August 24 (edited) On 8/17/2025 at 1:11 PM, ri702bill said: Ya gets what ya paid for...... Rustoleum is a good "backyard" type of product - but - you need to wait about a month in order to apply the decals. It has a very slow cure time. Some folks buy the paint in quarts, mixing it with a hardening catalyst. That is best applied with a HVLP spraygun. Having bought several times from Vinylguy, I was never diaappointed.... Bill I hear you on that curing the paint. Years ago when I was painting tractors, I used to hang them for a few days and then I put it on the second floor of the garage that I have. I had hooks already set up and I would hang everything for about a month in the summertime. It’s like an oven up there and cured the paint very well. Lots of work though that I do not do anymore. I had my fun. Edited August 24 by Retired Wrencher 2 Share this post Link to post Share on other sites
FarmallFarmer09 13 #41 Posted September 21 Hey what oil does the Charger 12 take in the rear end, (Hydrostatic) As well as the filter? filter is rusted over, Cant see numbers anymore. Regal red works well! Did a dump cart before the tractor so i could test colors. Looks great, Sandblasted and bondo for dents. 1 Share this post Link to post Share on other sites
953 nut 63,003 #42 Posted September 21 10 hours ago, FarmallFarmer09 said: what oil does the Charger 12 take in the rear end, (Hydrostatic) As well as the filter? The filter will be a NAPA 1410 or Wix 51410. Pull the transmission dip stick and put it on a clean white paper. If the oil is red/pink then use Automatic Transmission Fluid (ATF). If the oil is amber/clear the 10 W 30 motor oil should be used. 1 Share this post Link to post Share on other sites
