mazzbob 8 #1 Posted August 11, 2025 Hello all: I am at the crossroads…. I am looking to improve my work load and maintenance around my ½ acre property. I have a steep incline on the Driveway and Yard where the ground becomes a greasy slippery mud pit mess. Currently I have a IH-Cub Cadet 1450 w/ Blade, SS-Blower, Mowing Deck. It has it’s Good and Bad points as all GT’s seem to have. There is no perfect one. The Good: 1. Mows Well and Mulches due to modifying with X-Blades, does not bag well. The Bad: 1. Plows OK, but have a lot of Wheel Spin. (Wheel Weights/Chains + 2/5 Gal. Buckets of Concrete on Rear Platform, approximately 500# in total. 2. SS Blower/w Modded Flapper does not work well in Wet Snow, does not throw far and Clogs & a lot of Tire Spin. I have experimented with a couple of Bolens that had that adjustable rear locking Hub which when I had Wheel Spin I was able to stop it with Plowing and Blowing. However, the Mower Cut was troublesome and they did not Mulch well even with X Blades when compared to the Cub, not even close. The Bolens, SS Blower was just as bad as the Cub. It would not Throw the Wet Snow & clogged often. I’m looking at Wheel Horse Models that could improve my situation. However, I have no experience with them at all. What I would like is a Tractor with Hydraulic Lift, Rear Discharge Deck, Blade, & 2 Stage Blower also the possibility of future Independent Rear lift & FEL. I can create Mods if necessary So far I’m looking at GT14, 416H’s or C160 (better w/Kohler Engine, in my opinion). Interested in the 10 Pinion Differential with Posi Spring. (which I think will provide better traction). I’m not sure if the C160 Operational aspects are with the 2 speed Hydro 6 Gear Compared with the GT14 & 416H. Therefore, any wisdom, guidance & advice is truly appreciated. Share this post Link to post Share on other sites
TonyToro Jr. 2,442 #2 Posted August 11, 2025 Seeing with your input I would recommend a C-145,C-160, or a 417-A. A C-145 which I have plows snow beautifully the hydraulics are nice and strong and it already has hydraulic lift for the rear, but it may be a bit underpowered for a 2 stage blower. So If you’d really like a 2 stage blower I would go the a 417-A. Hydraulic lift, plenty of power, comfortable ride. The C-160 hydro would be a good choice also and should handle the 2 stage just fine. Or you can always get a single stage blower and put that infront of literally any Wheelhorse tractor with an attach o matic. Here’s a vid of my C-145 with a single stage with heavy wet snow. cm-chat-media-video-1:921c5e01-9961-3138-8733-92850a611703:10989:0:0.mov IMG_3377.mov 1 Share this post Link to post Share on other sites
Gasaholic 382 #3 Posted August 11, 2025 If y our driveway is gravel or dirt I would highly recommend a snow blade instead of a snowblower - Snowblowers don't like gravel driveways , however a snow plow blade won't give a damn. If you opt to go with a plow, then any model will do pretty well - anything from a C-81 to a C-175 (or newer models, 308 to 520 ) Only thing is you won't find 8 HP with hydro lift , so C-120, C-145, or looking to newer models 312-A, 314-A, 417-A, 520H probably al will do 14 HP is plenty of power for plowing and mowing , half acre property you'd do just fine with a 36:" rear or 42" rear discharge - they can all take wheel weights and easy enough to create weight boxes. Tire chains (especially those with ice cleats) - I don't have a steep drive (or mud pit at the bottom) but worked properly , a snow blade would pretty easily handle winter duities as effectively (if not more so) as a snowblower Granted, it is rare in my area any more to see a foot of snow at once, but we've had 3 feet plus at a time , and I'm usually plowed out before neighbors with snowblowers are half done. Strategic plowing is a must however as the season goes on, it's easy enough to build up large snowbanks that shrink your driveway space so a lot of my plowing is done in a sort of herringbone pattern from exit of driveway inwards - really kind of depends on just how much snow you regularly have to deal with I guess. As far as the mud pit at bottom of your hill, might look into doing a french drain to a back corner of property (I'm on a bit more than an acre, myself and run 36" rear for mowing...) Share this post Link to post Share on other sites
mazzbob 8 #4 Posted August 11, 2025 Thanks Very Much, for the replies. Sorry, Omitted the driveway is asphalt coated. Yeah, a French drain would help but BIg Big $18K. The Town has rules where it can only drain into a County Storm Drain. So it's 500 feet + Permit, Blueprints and Plans & County approved Contractor. So i'M better off getting a Tractor. Tony Nice Video on the snow, I get the same heavy packing type in the Hudson Valley. The yard, when wet and dry but its always kinda wet.... Thats why the interest in the posi rear.... I put 2 buckets on the back of the Cub, which are 100#'s each. Share this post Link to post Share on other sites
mazzbob 8 #5 Posted August 11, 2025 What is the difference between the Eaton 1100 and the 6 Speed Gear Hydrostatic ? are they both Hydros? Share this post Link to post Share on other sites
squonk 46,657 #6 Posted August 11, 2025 Load the rear tires. Share this post Link to post Share on other sites
TonyToro Jr. 2,442 #7 Posted August 12, 2025 5 hours ago, mazzbob said: What is the difference between the Eaton 1100 and the 6 Speed Gear Hydrostatic ? are they both Hydros? I’m not sure of the difference but would rather have the Eaton 1100 it’s a great transmission. And any parts that you may need are available. Share this post Link to post Share on other sites
TonyToro Jr. 2,442 #8 Posted August 12, 2025 3 hours ago, squonk said: Load the rear tires. Share this post Link to post Share on other sites
Easton Rich 1,239 #9 Posted August 12, 2025 10 hours ago, TonyToro Jr. said: Seeing with your input I would recommend a C-145,C-160, or a 417-A. A C-145 which I have plows snow beautifully the hydraulics are nice and strong and it already has hydraulic lift for the rear, but it may be a bit underpowered for a 2 stage blower. So If you’d really like a 2 stage blower I would go the a 417-A. Hydraulic lift, plenty of power, comfortable ride. The C-160 hydro would be a good choice also and should handle the 2 stage just fine. Or you can always get a single stage blower and put that infront of literally any Wheelhorse tractor with an attach o matic. Here’s a vid of my C-145 with a single stage with heavy wet snow. cm-chat-media-video-1:921c5e01-9961-3138-8733-92850a611703:10989:0:0.mov IMG_3377.mov I would like to add the 418-A is a great tractor also. Has the Eaton 1100 and an 18hp Kohler Magnum Twin. 417-418 are almost identical tho. Whichever you can find. I'd recommend ag tires or chains in the snow. If you've got any questions, ask! Share this post Link to post Share on other sites
Easton Rich 1,239 #10 Posted August 12, 2025 417-a - Wheel Horse for Sale - RedSquare Wheel Horse Forum Share this post Link to post Share on other sites
mazzbob 8 #11 Posted August 12, 2025 Thank You all. I will start looking.... This has helped a lot. Share this post Link to post Share on other sites
