horseman with no horse 31 #1 Posted August 7 my k181 carburetor on my 855 has a worn out idle set screw, and the tab that moves the throttle shaft is wore in the corner, coupled with the little bit of play thats already in the shaft and carburetor housings being a little worn, the tab on top the shaft where the governor linkage goes through gets stuck frequently past the idle set screw on the wrong side causing my engine to stall when i pull on the cable and its stuck. anything you guys thinking about to remedy this? Share this post Link to post Share on other sites
ebinmaine 72,987 #2 Posted August 7 Can you post pics? 1 Share this post Link to post Share on other sites
horseman with no horse 31 #3 Posted August 8 https://www.youtube.com/shorts/aK2s2TlSGAM heres a video 1 Share this post Link to post Share on other sites
ebinmaine 72,987 #4 Posted August 8 2 hours ago, horseman with no horse said: a worn out idle set screw, and the tab that moves the throttle shaft is wore in the corner For this I'd seriously consider bending the tab a little. 2 hours ago, horseman with no horse said: play thats already in the shaft On a small block Kohler carb this doesn't have an easy fix. The bore isn't bushed like the big block carbs. 2 1 Share this post Link to post Share on other sites
horseman with no horse 31 #5 Posted August 8 (edited) im willing to dril it out, smooth the shaft in my mini lathe. and smack a brash bushing in. but honestly the shaft and bore arent too wore. minor vacuum leak at worst yknow? im more considering just bending the tab like you suggested Edited August 8 by horseman with no horse Share this post Link to post Share on other sites
ebinmaine 72,987 #6 Posted August 8 If it's pretty minor you can compensate to some extent by settings. Certainly better to run a little rich if possible. 2 Share this post Link to post Share on other sites
wallfish 18,242 #7 Posted August 8 28 minutes ago, ebinmaine said: For this I'd seriously consider bending the tab a little. Appears to me like that tab is bent allowing that to happen so tweaking it back into position with some needle nose pliers will make it contact the end of the screw and eliminate the catch 3 Share this post Link to post Share on other sites
horseman with no horse 31 #8 Posted August 8 definitely gonna bend it lol. it is definitely chipped away but it may also be bent already, who knows lol 10 minutes ago, wallfish said: Appears to me like that tab is bent allowing that to happen so tweaking it back into position with some needle nose pliers will make it contact the end of the screw and eliminate the catch Share this post Link to post Share on other sites
wallfish 18,242 #9 Posted August 8 1 minute ago, horseman with no horse said: definitely gonna bend it lol. it is definitely chipped away but it may also be bent already, who knows lol Bend it. It just needs to make solid contact on that screw in a place on the tab where it won't bind up. 2 Share this post Link to post Share on other sites
horseman with no horse 31 #10 Posted August 8 im gonna do that. i still wanna restore this machine is my point yk Share this post Link to post Share on other sites
Kenneth R Cluley 595 #11 Posted August 8 You can also try just placing a small brass washer on throttle shaft as opposed to drilling and bushing. made a difference in one of my small block carbs. Share this post Link to post Share on other sites
