JR Pedersen 18 #1 Posted August 6, 2025 I'd like to add the headlight kit since mine only had the plastic panel plate. I've researched online and haven't found anything. Thoughts? 1 Share this post Link to post Share on other sites
rjg854 12,834 #2 Posted August 6, 2025 Call AZ tractor, he may have the headlight bucket and lens that you'd need if you want to go original. Then just use LED bulbs in the sockets. 5 Share this post Link to post Share on other sites
ri702bill 11,147 #3 Posted August 6, 2025 Be sure to add a fuse before the light switch and a ground wire from the headlight bucket back to the frame. WH did not have one as OE, grounded thru the hood & hinge. Poor design. 1 Share this post Link to post Share on other sites
