C100 0 #1 Posted August 6, 2025 I have both front pulleys on my mower deck needing replacement. At least one for sure, better to do both as they are loose and noisy. I sent one e-mail to a dealer and awaiting a reply. Anyone have a resource, a suggestion for a suitable replacement. These are the two pulleys in the front of the deck, not the two rear spindle type that I can grease. Thank you for any help. 37" side discharge from 1990 on a 310-8. Share this post Link to post Share on other sites
953 nut 63,982 #2 Posted August 6, 2025 Call Lincoln at A-Z tractor, he is great to work with and sells good used Wheel Horse parts. https://www.a-ztractor.com/ 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,981 #3 Posted August 6, 2025 Are both pulleys V-type using a 6-sided belt or is one flat and one V-type using a 4-sided belt? Both are out there. Share this post Link to post Share on other sites
C100 0 #4 Posted August 6, 2025 It’s a very long belt for sure. It is a four-sided V-belt. That passes both pulleys. Thank you. Share this post Link to post Share on other sites
clueless 3,347 #5 Posted August 8, 2025 On 8/6/2025 at 7:25 AM, gwest_ca said: Are both pulleys V-type using a 6-sided belt or is one flat and one V-type using a 4-sided belt? Both are out there. Yep, 1990 37" deck, 6 sided belt. Share this post Link to post Share on other sites
