Redman408 0 #1 Posted July 30 I have a wheel horse rototiller that I had bought a while ago, I just have never found the right wheel horse to mount it onto and I personally think this commando 8 i have should be powerful enough to run the tiller, I would really like some other people's input on how I would go about mounting it and making the pto clutch work, thank you Share this post Link to post Share on other sites
ebinmaine 76,081 #2 Posted July 31 Can you show pics of: The model numbers on the tractor and tiller? The tiller as a whole? Any brackets or pulleys you have? What PTO is on the tractor? Share this post Link to post Share on other sites
ri702bill 10,781 #3 Posted July 31 My 2 cents.... 8 HP is marginal to run a tiller, even if is in great running condition. Best used to till an area free of rocks & roots, not unbroken unknown soil. The Commando 8 is a 4 speed.... you really need the low range 6 or 8 speed to be able to run the engine at WOT and still have a slow enough ground speed. Or an automatic? Right implement, wrong tractor..... 4 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #4 Posted July 31 The very first tillers had their own engine so that got the tiller speed up. They offered a speed reduction kit (SR-64) to get the tractor ground speed down. Also used for snowthrower applications. The transmission pulley was changed to 7-1/2" with the necessary idlers for clutch action. Do not know how effective it was but something to consider. This does not provide a belt source to drive a tiller. Share this post Link to post Share on other sites
Pullstart 68,558 #5 Posted July 31 I’ve done it with my 8 hp 8 speed 502. I wouldn’t recommend it honestly! 1 Share this post Link to post Share on other sites
ri702bill 10,781 #6 Posted July 31 4 hours ago, Pullstart said: with my 8 hp 8 speed 8 speed - there you have it..... 1 Share this post Link to post Share on other sites
Pullstart 68,558 #7 Posted July 31 12 minutes ago, ri702bill said: 8 speed - there you have it..... But the small pulley still taxes that little K-181 pretty hard. 1 Share this post Link to post Share on other sites
ri702bill 10,781 #8 Posted July 31 2 minutes ago, Pullstart said: But the small pulley still taxes that little K-181 pretty hard. Yup - only 8 little WH squirrels on that hamster wheel!! 1 Share this post Link to post Share on other sites
kpinnc 16,319 #9 Posted July 31 (edited) I fully agree with the others on the thread. Firstly, the 36 inch rear tillers were some of the absolute best attachments Wheel Horse ever made. I would say this concerning horsepower: I tilled with a 310-8 for years. It was very strong, even in solid red clay that was loaded with rocks. That being said, 10 horsepower isn't much, but the low range on the tractor is what allows less power to do so much work. The slower ground speed allows the tiller to take a far smaller bite. Point being? A healthy 8 hp engine might be enough under certain conditions, but the low range of an 8 speed is what is an absolute necessity. Edited July 31 by kpinnc 3 Share this post Link to post Share on other sites
Pullstart 68,558 #10 Posted July 31 1 hour ago, kpinnc said: I tilled with a 310-8 for years. It was very strong, even in solid red clay that was loaded with rocks. That being said, 10 horsepower isn't much, but the low range on the tractor is what allows less power to do so much work. The slower ground speed allows the tiller to take a far smaller bite. I think a K-241 vs K-181 has a significantly advanced torque curve from the longer rod. It’s not fair to rate them only 2 powers apart, when we need the torque numbers. After all, horsepower is how fast we can hit a wall. Torque is how far we can push it. 2 Share this post Link to post Share on other sites
kpinnc 16,319 #11 Posted July 31 (edited) 1 hour ago, Pullstart said: I think a K-241 vs K-181 has a significantly advanced torque curve from the longer rod. It’s not fair to rate them only 2 powers apart, when we need the torque numbers. After all, horsepower is how fast we can hit a wall. Torque is how far we can push it. I would agree with that. There is a fairly large torque increase from small block to big block on a K series or Magnum Kohler. Stroke, compression, even the mass of the individual flywheel makes a difference. My point was you don't need 25hp to run a tiller and that low range alone has more impact on the tiller performance than does pure horsepower. All that being said, tillers have been used with small block Kohler-equipped tractors successfully since the 1960s (especially after 1967). Obviously, as with any powered implement the performance rises with the amount of power applied. That is a given. Edited July 31 by kpinnc 3 1 Share this post Link to post Share on other sites
horseman with no horse 55 #12 Posted October 8 yeah the sr reduction kit would be smart. if you had a 10hp or more and a 8/6 speed that would make more sense for a tiller. or a hydro. something like a 1076 would be perfect..... Share this post Link to post Share on other sites
kpinnc 16,319 #13 Posted October 8 22 minutes ago, horseman with no horse said: or a hydro. something like a 1076 would be perfect..... A hydro will work, but wouldn't be a first choice for use with a tiller. You have to constantly adjust "back" to prevent the tiller from pushing the hydro. Low range on a 6/ 8 speed is ideal. And yes 10hp is plenty for a tiller. 2 1 Share this post Link to post Share on other sites
ri702bill 10,781 #14 Posted October 8 10 hours ago, horseman with no horse said: yeah the sr reduction kit would be smart. Except.... it turns your 4 speed tractor to be like an 8 speed in low range - ALL the time. Not an overall practical solution unless that tractor is dedicated to the tiller..... 1 Share this post Link to post Share on other sites
horseman with no horse 55 #15 Posted October 8 basically get a 10hp machine with hi/low. and your peachy. maybe consider some good traction options like agg tires or chains. i dont know much about tilling lol 1 Share this post Link to post Share on other sites
horseman with no horse 55 #16 Posted October 8 you can probably experiment with different weight setups too. more weight in the back for traction/more in the front for steering depending on what frame you have (short frame, mid, or long frame) 1 Share this post Link to post Share on other sites
