bennyt192 2 #1 Posted July 27, 2025 Hi, I am currently repairing a toro wheelhorse 520lxi with the kawasaki fd620d engine. I replaced the lower radiator hose and when I went to test it, I noticed the temperature gauge seems to be fluctuating a lot. It will slowly go up until it almost reaches the red and then it will drop back down. It constantly does this. I bled the air out at the water pump. I’m not sure if there’s another bleeder screw I’m missing. Maybe this is normal for these tractors? Any advice is much appreciated. Share this post Link to post Share on other sites
RED-Z06 2,700 #2 Posted July 27, 2025 Is the belt good and snug with no slipping for the fan? Radiator is full, surge tank showing full? How far down does it come from the near red point? Share this post Link to post Share on other sites
JoeM 9,389 #4 Posted July 28, 2025 I have an LXI with a loader and it does that it’s just the thermostat opening and closing you do want to make sure the radiator is full so when the engine is cold, take the cap off and make sure the radiator is filled up to the top 1 Share this post Link to post Share on other sites
bennyt192 2 #5 Posted July 28, 2025 I checked the belt and it’s tight. The coolant reservoir and radiator are full. The needle gets a little over 3/4 and then drops back down. It never overheats. I’m just wondering if the needle is supposed to remain steady or if it’s ok that is fluctuating. JoeM says this is normal? Thanks for the responses 1 Share this post Link to post Share on other sites
pfrederi 19,459 #6 Posted July 28, 2025 Most thermostats have a range. They start to open at the labeled Temp then open wider until fully open ..usually 10-15 degrees hotter than just starting to open temp. Share this post Link to post Share on other sites
JoeM 9,389 #7 Posted July 28, 2025 3 hours ago, bennyt192 said: if it’s ok that is fluctuating I will take some pics tomorrow of mine.....if I can remember. Share this post Link to post Share on other sites
JoeM 9,389 #8 Posted July 29, 2025 @bennyt192 Got vid of the cycling. The machine is not under a load, it is more aggressive when running it hard. Keep in mind that temp gauge is not a precision gauge just a general indicator of what is going on with the coolant. Share this post Link to post Share on other sites
OoPEZoO 582 #9 Posted July 30, 2025 I have a long history with BMW motorcycles. It is often said that no one ever knew that they overheated until they put temperature gauges on them 1 Share this post Link to post Share on other sites
bennyt192 2 #10 Posted July 30, 2025 4 hours ago, JoeM said: My tractor is doing the same thing. The video helped me out a lot thanks! 1 Share this post Link to post Share on other sites
