Mattthetrac 12 #1 Posted July 23, 2025 I was cleaning up a bunch of oil around the tractor and on the front right side of the engine I found a wire that has been cut or destroyed somehow. I am wondering if it is important to get my tractor to start. Any info is greatly appreciated. Share this post Link to post Share on other sites
rmaynard 17,582 #2 Posted July 23, 2025 (edited) I have no idea what you are circling. See if you can find where the wire originates. Edited July 24, 2025 by rmaynard Share this post Link to post Share on other sites
953 nut 69,337 #3 Posted July 23, 2025 I do not own the model you are working on so a bit more information could help figure this out. I your previous post you said you were charging the battery to find out what was and wasn't working as it should. So tell us, what is working and what isn't working, that will help us to figure out what the mystery wire goes to. Your engine is a Lauson V70 which was bought out by Tecumseh. I was unable to find a wiring diagram for your model but the 1969 Workhorse model has a 7 HP Tecumseh engine which has a horizontal crankshaft (yours is a vertical crankshaft) but the wiring may be similar enough to help figure this out. According to the drawing there are only three small wires going to your engine, what color is the cut wire? 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,539 #4 Posted July 24, 2025 1 hour ago, 953 nut said: I do not own the model you are working on so a bit more information could help figure this out. I your previous post you said you were charging the battery to find out what was and wasn't working as it should. So tell us, what is working and what isn't working, that will help us to figure out what the mystery wire goes to. Your engine is a Lauson V70 which was bought out by Tecumseh. I was unable to find a wiring diagram for your model but the 1969 Workhorse model has a 7 HP Tecumseh engine which has a horizontal crankshaft (yours is a vertical crankshaft) but the wiring may be similar enough to help figure this out. According to the drawing there are only three small wires going to your engine, what color is the cut wire? Looks to me either red or orange. 1 Share this post Link to post Share on other sites
Mattthetrac 12 #5 Posted July 24, 2025 I have identified the cable as the ignition ground wire and will purchase new wire to reconnect the two ends. 1 1 Share this post Link to post Share on other sites
Mattthetrac 12 #6 Posted July 24, 2025 2 hours ago, 953 nut said: I do not own the model you are working on so a bit more information could help figure this out. I your previous post you said you were charging the battery to find out what was and wasn't working as it should. So tell us, what is working and what isn't working, that will help us to figure out what the mystery wire goes to. Your engine is a Lauson V70 which was bought out by Tecumseh. I was unable to find a wiring diagram for your model but the 1969 Workhorse model has a 7 HP Tecumseh engine which has a horizontal crankshaft (yours is a vertical crankshaft) but the wiring may be similar enough to help figure this out. According to the drawing there are only three small wires going to your engine, what color is the cut wire? It was indeed the ignition ground wire. Thank you for all the help and I will probably keep asking questions😂 2 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #7 Posted July 24, 2025 Matthetrac: This is how you learn to work on them. It’s always handy to have extra wire and normal things like that so problems come up you’re ready. Enjoy the project. 2 Share this post Link to post Share on other sites
Pullstart 71,255 #8 Posted July 24, 2025 8 hours ago, Mattthetrac said: I will probably keep asking questions😂 9 hours ago, Mattthetrac said: I have identified the cable as the ignition ground wire and will purchase new wire to reconnect the two ends. Thank you for the follow-up, to let us know what it was. Many times we never know what happened! 2 Share this post Link to post Share on other sites
peter lena 10,065 #9 Posted July 24, 2025 @Mattthetrac always have these handy ,https://www.google.com/search?q=alligator+clip+wires&rlz=1C1CHBF_enUS866US866&oq=aligator+clip+&gs_lcrp=EgZjaHJvbWUqCQgCEAAYChiABDIGCAAQRRg5MgwIARAAGAoYsQMYgAQyCQgCEAAYChiABDIJCAMQABgKGIAEMgkIBBAAGAoYgAQyCQgFEAAYChiABDIJCAYQABgKGIAEMgkIBxAAGAoYgAQyCQgIEAAYChiABDIJCAkQABgKGIAE0gEJMTM4NzlqMGo0qAIIsAIB8QVkjSzkS_0saw&sourceid=chrome&ie=UTF-8 , quickly / easily jump over a problem , lets you move thru a problem area , pete 1 Share this post Link to post Share on other sites
953 nut 69,337 #10 Posted July 24, 2025 9 hours ago, Mattthetrac said: Thank you for all the help and I will probably keep asking questions You are quite welcome and we look forward to seeing your progress. 1 Share this post Link to post Share on other sites
8ntruck 9,301 #11 Posted July 24, 2025 10 hours ago, Mattthetrac said: It was indeed the ignition ground wire. Thank you for all the help and I will probably keep asking questions😂 Keep on asking questions. That is how we learn - the only dumb question is the one that you don't ask. 1 Share this post Link to post Share on other sites
