mrharris12 33 #1 Posted July 20 Was curious if anyone has run into this issue before. In the pictures below you can see that the handle for the height adjustment on the deck is twisted when trying to adjust the height of the deck higher, as well the pin doesn't stick through the holes either and its diagonal to the holes. I doubt it is the spring and im curious if I need to adjust the carriage bolts on the deck and slide the bracket and the other piece closer. Does anyone have a solution? WHD1.heif WHD2.heif WHD3.heif Share this post Link to post Share on other sites
ANTPER 208 #2 Posted July 21 16 hours ago, mrharris12 said: Was curious if anyone has run into this issue before. In the pictures below you can see that the handle for the height adjustment on the deck is twisted when trying to adjust the height of the deck higher, as well the pin doesn't stick through the holes either and its diagonal to the holes. I doubt it is the spring and im curious if I need to adjust the carriage bolts on the deck and slide the bracket and the other piece closer. Does anyone have a solution? WHD1.heif 1.91 MB · 8 downloads WHD2.heif 1.85 MB · 2 downloads WHD3.heif 2 MB · 2 downloads I would try what you just mentioned. Adjust the carriage bolts and slide bracket over to take up gap. Did exact same thing on mine days ago. Share this post Link to post Share on other sites
mrharris12 33 #3 Posted July 23 On 7/21/2025 at 8:07 AM, ANTPER said: I would try what you just mentioned. Adjust the carriage bolts and slide bracket over to take up gap. Did exact same thing on mine days ago. Sorry for the late update, but I had to go and get new carriage bolts and nuts for it since they were pretty shot and cant complain since they have been on there for 40 years. But getting those installed and getting the handle in place did the trick 1 Share this post Link to post Share on other sites
