spedini 2 #1 Posted July 20, 2025 Please excuse my ignorance, but what model do I have? Yes, I know the engine is incorrect, the previous owner put that 5hp Briggs in there. Thank you, Arnie 1 Share this post Link to post Share on other sites
Achto 30,450 #2 Posted July 20, 2025 2 hours ago, spedini said: but what model do I have? You appear to have an RJ. If it has a 3 speed transmission then it is either a 1958 or 1959 RJ58. If it has a vari-drive, then it is an earlier model. Share this post Link to post Share on other sites
kpinnc 16,515 #3 Posted July 20, 2025 RJ-58/59. Can be tricky to define which, but likely one or the other. Nice save! Share this post Link to post Share on other sites
spedini 2 #4 Posted July 20, 2025 (edited) 3 speeds forward and it has reverse. H pattern Thank you. Edited July 20, 2025 by spedini 1 Share this post Link to post Share on other sites
wallfish 18,855 #8 Posted July 20, 2025 (edited) A very nice find! Just FYI Missing the belt guard and exhaust heat shield. Rear fenders were an customer option on those tractors so either way it is correct. That pedal on the right is for a dozer blade, it's used to release the indexing pin on the blade. Ask the seller if they still have the blade. Looks as though a choke knob was added under the steering wheel where the kill switch was once located. That solid seat pan was used on later RJ-58s sold in 1959 and on early 1960 tractors. All of those tractors were badged as RJ-58 even though they may have been made and or sold in 1959. But you can check the casting code date on the trans. Edited July 20, 2025 by wallfish 3 Share this post Link to post Share on other sites
wallfish 18,855 #9 Posted July 20, 2025 Without the belt guard the belt may not slip on the engine pulley which is the clutching. If the belt doesn't stop spinning it will grind gears when shifting it. This can be solved without a belt guard until you find one or just use it. Is it grinding gears when shifting now? 1 Share this post Link to post Share on other sites
kpinnc 16,515 #10 Posted July 21, 2025 3 hours ago, wallfish said: All of those tractors were badged as RJ-58 even though they may have been made and or sold in 1959. Literally more than ten times the number of RJs were built in 59 than in 58. Statistically, it's likely a 59. Seems like the only way to determine which one is would be to break down the date stamp on the transmission, and I don't remember what the cutoff is nor can I remember how to decipher Julian dates. Maybe one of the RJ gurus can chime in and help. Share this post Link to post Share on other sites
oliver2-44 11,137 #11 Posted July 21, 2025 The casting dated If I remember correctly the 1st Character is a letter. A= January, etc (skip I ). The next neuter is months and the lady 2 are year. 1 Share this post Link to post Share on other sites
wallfish 18,855 #12 Posted July 21, 2025 (edited) 8 hours ago, kpinnc said: Maybe one of the RJ gurus can chime in and help. There is not a single tractor that was ever badged as a RJ-59 from the factory. They were ALL badged RJ-58 even if they were built and or sold in 1959 as stated. Even the trans date codes that have 59 on them still have a factory tag of RJ-58. Letter - equals month except for the letter I was not used.( Probably because it could be confused with the number 1 ) the second number - equals the day of that month and there will not be a number in the middle that os over 31 the last number - equals the last two digits of the year Edited July 21, 2025 by wallfish Share this post Link to post Share on other sites
kpinnc 16,515 #13 Posted July 21, 2025 (edited) 3 minutes ago, wallfish said: Literally there is not a single tractor that was ever badged as a RJ-59 from the factory. They were ALL badged RJ-58 even if they were built and or sold in 1959 as stated. No one has ever been able to produce a factory label that had RJ-59 on it. I hope my post didn't mislead. You are correct. None were called RJ-59. The only RJ I ever owned was a 1959 model. At least that was the consensus back then. I got into the wrong habit of referring to mine as a RJ-58/59. I guess it's stuck. Edited July 21, 2025 by kpinnc Share this post Link to post Share on other sites
wallfish 18,855 #14 Posted July 21, 2025 People do call them RJ-59s but if the factory label reads RJ-58, then it IS a RJ-58, even though it could have been built or sold in 59. I'll stick with my initial call, it's a RJ-58 no matter what the trans code reads. Share this post Link to post Share on other sites
wallfish 18,855 #15 Posted July 22, 2025 On 7/20/2025 at 10:33 PM, kpinnc said: None were called RJ-59. I was wrong! This is the first document I have ever seen in which WH actually refers to a RJ-59. Admittedly I have not read a ton of WH documents and this was a service bulletin from 1964 1 Share this post Link to post Share on other sites
malcolmfox2@gmail.com 0 #16 Posted July 24, 2025 What year and model is this? Share this post Link to post Share on other sites
malcolmfox2@gmail.com 0 #17 Posted July 24, 2025 Please help Share this post Link to post Share on other sites
Pullstart 68,616 #18 Posted July 24, 2025 8 hours ago, malcolmfox2@gmail.com said: Please help L-157(I believe) otherwise known as a Lawn Ranger. 1 1 Share this post Link to post Share on other sites
rjg854 12,716 #19 Posted July 24, 2025 9 hours ago, malcolmfox2@gmail.com said: What year and model is this? yeap Lawn Ranger 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,283 #20 Posted July 24, 2025 It appears to have the indent where the decal is on the belt guard…which indicates a 65 or 66 lawn ranger.. other than that theres no real difference from the 65-67 lawn rangers… Share this post Link to post Share on other sites
953 nut 63,548 #21 Posted July 24, 2025 1 hour ago, Pullstart said: L-157(I believe) otherwise known as a Lawn Ranger. Kevin nailed it. The seat is from 1965 to 1967 but that steering wheel was a 1967 only style. Here is a copy of the owner's manual. Share this post Link to post Share on other sites
spedini 2 #22 Posted July 24, 2025 On 7/20/2025 at 4:45 PM, wallfish said: Without the belt guard the belt may not slip on the engine pulley which is the clutching. If the belt doesn't stop spinning it will grind gears when shifting it. This can be solved without a belt guard until you find one or just use it. Is it grinding gears when shifting now? It does not grind gears, It never has. Shifts quietly and smoothly. Share this post Link to post Share on other sites
