Moohampshire 11 #1 Posted Wednesday at 08:40 PM Totally rebuilt a 77 C-160. New battery and when I turn ignition to first spot lights work. When I turn to crank the engine-nothing. Thought it was a bad ignition switch so I got a new one. Same thing. I have power to both sides of the solenoid. Engine turns over by hand. When key is turned to start engine I hear nothing from starter. Issue has to be electrical Any help will be greatly appreciated Share this post Link to post Share on other sites
ebinmaine 72,425 #2 Posted Wednesday at 08:47 PM Do you have a test light? Share this post Link to post Share on other sites
Handy Don 13,980 #3 Posted Wednesday at 08:52 PM And do you have the wiring diagram? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,450 #4 Posted Wednesday at 08:58 PM Share this post Link to post Share on other sites
squonk 43,735 #5 Posted Wednesday at 09:25 PM " Power on both sides of solenoid" I'm assuming you hear a click from the solenoid when in the start position. If so, could be a bad starter but "cents" you restored the tractor I'm betting you painted the engine and where the starter bolts on and the ground cable connects, you need to clean off the paint at these locations to establish grounds. 7 1 Share this post Link to post Share on other sites
8ntruck 7,781 #6 Posted Thursday at 01:06 AM The PTO lever switch comes to mind, too. I think it is wired between the key switch and the starter solonoid. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,450 #7 Posted Thursday at 08:01 AM If you have power going to the starter the solenoid has closed. Power in both large cables. It is either stuck there requiring solenoid replacement or the wiring is OK and the starter motor has failed to run. Maybe the starter is not properly grounded as already noted. Share this post Link to post Share on other sites
Pullstart 66,630 #8 Posted Thursday at 10:39 AM Bad ground is my first thought too. 2 Share this post Link to post Share on other sites
953 nut 59,779 #9 Posted Thursday at 10:46 AM 14 hours ago, Moohampshire said: Totally rebuilt a 77 C-160. I bet you painter it all the way! May have painted everything to the point that an electrical ground sufficient to handle the starter load can't be made. Run your ground cable to the engine block mounting point for the starter. Share this post Link to post Share on other sites
Moohampshire 11 #10 Posted Thursday at 11:30 AM Thanks for all the great ideas as I will go through all of them today and see what I get. Also thanks for the electrical diagrams. 4 Share this post Link to post Share on other sites
