River Rat 1 #1 Posted July 12 My question is what is the procedure to set the eccentric cam on the speed control plate? This is on my 11-14KE01 tractor. I took all the parts off as they were rusty and didn't fully move properly. Cleaned them and painted all non moving parts. there is a slight grove in the eccentric, should try to position it in the same place or is it suppose to move as the plate passes by? I found the instructions to adj the motion control eccentric . So I will work on getting the set properly. Thanks for any advice I get. River Rat Share this post Link to post Share on other sites
JoeM 8,542 #2 Posted July 13 Make sure the rear tires are off the ground, recommend on jack stands. Before starting and making adjustments. Get the neutral set first with the lever then the cam. Make sure the trans is warmed up too. Share this post Link to post Share on other sites
cleat 7,436 #3 Posted July 13 I assume this is the same info as you already have but maybe not. Wheel horse 520H service manual.pdf Work Horse service manual.pdf Share this post Link to post Share on other sites
