Cjwv1975 117 #1 Posted July 11, 2025 Snapped the little claw on throttle lever assembly that holds cable. Any idea on fix or replacement? I.rigged something up but it doesnt go get to full rpm and the lever slowly creeps back to idle. Any ideas? Thanks Share this post Link to post Share on other sites
953 nut 68,507 #2 Posted July 11, 2025 Perhaps a small fuel line clamp will get it done. 1 Share this post Link to post Share on other sites
oliver2-44 11,694 #3 Posted July 11, 2025 11 hours ago, Cjwv1975 said: Snapped the little claw on throttle lever assembly that holds cable. Any idea on fix or replacement? I.rigged something up but it doesnt go get to full rpm and the lever slowly creeps back to idle. Any ideas? Thanks A picture would help us better understand what broke. Share this post Link to post Share on other sites
953 nut 68,507 #5 Posted July 12, 2025 That is what I was thinking about when I suggested a small hose clamp. Run the clamp around the cable conduit and the piece of steel sticking down and tighten the snot out of it. I once attempted to brave the conduit to what was left of the bracket but the conduit became brittle and broke off a few weeks later. Share this post Link to post Share on other sites
Handy Don 17,316 #6 Posted July 12, 2025 13 hours ago, Cjwv1975 said: The nearby metal is already compromised so a simple patch-up isn’t likely to work. I think you’ll need to replace the entire control or at least the last inch or so of the holder. if you can fabricate a copy of the end with the clinching jaws, you can attach it to the existing control with a couple of small bolts. Share this post Link to post Share on other sites
wallfish 20,510 #7 Posted July 12, 2025 (edited) Easier to weld a piece on but you can bolt a piece on too You can find all kinds of small brackets at the hardware store to modify Edited July 12, 2025 by wallfish 2 1 Share this post Link to post Share on other sites
Cjwv1975 117 #8 Posted July 12, 2025 1 hour ago, wallfish said: Easier to weld a piece on but you can bolt a piece on too You can find all kinds of small brackets at the hardware store to modify Sometimes the easiest thing goes unnoticed lol. Thanks thats what am doing. Was thinking about brazing a piece of tube on than crimping it but thats much simpler 1 Share this post Link to post Share on other sites
