Wilsonrl48747 0 #1 Posted September 19, 2009 I have a snowblade for my C120, but it did not come with the whole bracket that attaches to the rear axle. Looking at the parts master diagram, it says I need the top plate, and an L shaped spacer. My question is do I need this spacer? I can fab the top plates and pick up a carriage bolt and nut at the hardware store for a few bucks. If I order the plate, spacer, bolts and nuts its going to be about $70. I took a picture of what I have. Thanks Attached Image Share this post Link to post Share on other sites
sawhorse 0 #2 Posted September 19, 2009 My rear tach-a-matic did not come with a spacer. It did come with a top plate - an item that (like you said) could be easily fabricated. Perhaps the "l-shaped spacer" is a piece of angle iron used as a top plate on the left side of the tractor for attachment of a spring to assist lifting a rototiller. I read somewhere here about a clip that keeps the tach-a matic locked over the bar. I couldn't figure out where that clip would go so I zip-tied the tach-a-matic locking cam onto the bar. It hasn't popped out yet so I guess it works. Share this post Link to post Share on other sites
bitten 134 #3 Posted September 20, 2009 Rob: You can get the bracket off of E-Bay, they usally arent to bad of a price. Jon: The "clip" is just a cotter pin going thru two holes, one on the cam and the other one is on the angle plat. Share this post Link to post Share on other sites
sawhorse 0 #4 Posted September 20, 2009 I couldn't find the hole for the cotter pin to secure the cams. I'll take another look. Share this post Link to post Share on other sites
wheel horse 1045 2 #5 Posted September 20, 2009 you can fab the parts you are refering to and you dont need the L shaped spacer Share this post Link to post Share on other sites
rick 258 #6 Posted September 20, 2009 The only reason I can see for the spacer is that it makes the hitch fit snug fore & aft. Being somewhat anal, I procured and used the spacers.....also, on my rear hitch, the release levers are secured by cute little clevis pins and hairpin clips. Share this post Link to post Share on other sites
Nick 13 #7 Posted September 20, 2009 Dont think I have ever even seen that L shaped spacer on a hitch. Share this post Link to post Share on other sites
Kelly 1,035 #8 Posted September 20, 2009 Out of the dozens of axle hitches I have, I only have one that had the L spacers, some use a long piece of angle iron with a hole near the back on the left side in place of the top plate, to hook a spring to for a tiller, and only about 1/3 of my hitches have the hole to pin the lever in place, but it would not be hard to drill to except a pin, and if you plan to use a tiller I highly recomend it, I've had the tiller drop out a couple of times. Share this post Link to post Share on other sites
