Scott from ontario 3 #1 Posted July 9, 2025 What oil can I use in the motor summer time 3/4 acres of grass to cut gets warm Share this post Link to post Share on other sites
kpinnc 17,149 #2 Posted July 9, 2025 Straight SAE 30W. Rotella makes a very good oil for these old flatheads. Winter you should probably use 10W30 for easier starting. 4 Share this post Link to post Share on other sites
peter lena 9,763 #3 Posted July 10, 2025 @Scott from ontario suggest , you do a rear axel drain after the cut , inspect the oil statis before the cut , condition / level. that oil will get hot and drain very easily , also jack up supported front end , for a more thorough drainage . opportunity , pete Share this post Link to post Share on other sites
