Scott from ontario 3 #1 Posted July 7, 2025 Good evening everyone I can’t find the governor shaft spacer for sale for a 1963 wheel horse tractor 953 is there something else I can use for it and if so what size would it have to be? thank you in advance Share this post Link to post Share on other sites
rmaynard 16,771 #2 Posted July 7, 2025 26 minutes ago, Scott from ontario said: Good evening everyone I can’t find the governor shaft spacer for sale for a 1963 wheel horse tractor 953 is there something else I can use for it and if so what size would it have to be? thank you in advance Could you point out on the parts list the spacer you are looking for? Share this post Link to post Share on other sites
Scott from ontario 3 #3 Posted July 7, 2025 The round tube that holds the governor arm in place I have the part with the I’ll call flap on it but the tube part I don’t have and can’t find Share this post Link to post Share on other sites
Scott from ontario 3 #4 Posted July 7, 2025 I’m also not sure how this part goes if anyone would have a picture of it before installing it are they to be open or closed and or how it goes Share this post Link to post Share on other sites
953 nut 63,547 #5 Posted July 7, 2025 53 minutes ago, Scott from ontario said: round tube that holds the governor arm in place Not sure if this will help but it is from the K-241 parts manual. 47 minutes ago, Scott from ontario said: not sure how this part goes I use a wood dowel to hold the two parts of the cam shaft in place while slipping the shims in place then push the pin intoplace which pushes the dowl out. Share this post Link to post Share on other sites
Scott from ontario 3 #6 Posted July 8, 2025 Part number t1 that’s the part I can’t find and on the cam shaft not sure on how the other part goes back on Share this post Link to post Share on other sites
rmaynard 16,771 #7 Posted July 12, 2025 On 7/7/2025 at 8:00 PM, Scott from ontario said: Part number t1 that’s the part I can’t find and on the cam shaft not sure on how the other part goes back on I'm not sure whether it was a mis-type, but T1 does not go on the cam shaft. It goes on the governor shaft. Share this post Link to post Share on other sites
