Mike'sHorseBarn 3,684 #1 Posted July 4, 2025 I have a 16hp I'm putting valves in and I thought you set the end gap at top dead center? This one isn't working out that way both valves are a little open at tdc with zero end gap? Am I wrong or is the acr broken? Share this post Link to post Share on other sites
squonk 48,207 #2 Posted July 4, 2025 Try rotating the crank 1 revolution. 1 Share this post Link to post Share on other sites
Gasaholic 396 #3 Posted July 4, 2025 (edited) 1 hour ago, Mike'sHorseBarn said: I have a 16hp I'm putting valves in and I thought you set the end gap at top dead center? This one isn't working out that way both valves are a little open at tdc with zero end gap? Am I wrong or is the acr broken? Because you're at TDC on exhaust stroke. You need TDC on Compression stroke (or roll piston just PAST TDC compression stroke by about 1/4 inch down to be 100% sure you're not touching any part of the ACR) Alternatively if you don't want to be bothered figuring TDC and stuff, roll engine til one of the valves is full open and check clearance on the other valve. Edit to add: just an aside Valves have a bit of "overlap" at TDC on Exhaust stroke as the exhaust valve closes, intake starts to open, and that causes the exhaust flow to start pulling fresh air IN as exhaust exits , giving intake a tiny bit of head start. Edited July 4, 2025 by Gasaholic Share this post Link to post Share on other sites
ri702bill 13,162 #4 Posted July 4, 2025 New or used valves?? They are left long for fitting on the non-adjustable tappet 7 & 8 hp engines if new.... Share this post Link to post Share on other sites
