pylp 6 #1 Posted July 3, 2025 (edited) Hello I have a c160 Kohler k341s engine it will only start with a tiny bit of starting fluid then fires right up runs fine. But when I get on to mow riding and cutting it dies out about after a minute or two if it just sits running with the blades on it run till I shut it off I put a brand new carb on and all new fuel lines I'm stumped I checked the manual to check the carb screws there set to OEM from manual and I have tried turning the idle screw up two turns while it raises the rpms high but still dies when driving and mowing thanks Edited July 3, 2025 by pylp Share this post Link to post Share on other sites
1968Commando 171 #2 Posted July 3, 2025 (edited) Take the gas cap off and see if it still dies Edited July 3, 2025 by 1968Commando 2 Share this post Link to post Share on other sites
pylp 6 #3 Posted July 3, 2025 Ok and try driving it and cutting what does that mean with the gas cap off Share this post Link to post Share on other sites
pylp 6 #4 Posted July 3, 2025 Still died although seemed to run a little better but died out Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,998 #5 Posted July 3, 2025 2 hours ago, pylp said: I checked the manual to check the carb screws there set to OEM from manual Those settings are where the engine should start and run which it does. Now you need to fine tune each screw for optimum performance at idle and at high speed. Try 1/8 turn each way from the initial setting to see where the highest rpm is achieved. Turning screws in leans the fuel mixture and turning out richens the mixture. You may find having them set on the rich side of best rpm provides the best performance. Share this post Link to post Share on other sites
rmaynard 16,864 #6 Posted July 3, 2025 Sounds like a weak fuel pump. 1 Share this post Link to post Share on other sites
953 nut 64,108 #7 Posted July 3, 2025 Gasoline engine do require fuel but they also require spark at the correct time to run under a load. Section 8 of this service manual will guide you through the static timing process. The ignition points gap also sets engine timing. Share this post Link to post Share on other sites
pylp 6 #8 Posted July 4, 2025 What is the second screw in the side of the carb manual says fuel air mixture but ive adjusted both the top for sure is idle speed Share this post Link to post Share on other sites
Gasaholic 352 #9 Posted July 4, 2025 1 hour ago, pylp said: What is the second screw in the side of the carb manual says fuel air mixture but ive adjusted both the top for sure is idle speed Depends on if you have the Carter carburetor or the Walbro? Share this post Link to post Share on other sites
