whb100 6 #1 Posted July 2, 2025 I need blades for a 42" side discharge deck. Also think the little fuel pump is weak. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,961 #2 Posted July 2, 2025 Click on the fuzzy picture in the link. The original blades are on the page that comes up. Use that part number to search for replacements. Here is an original parts list for your engine. Need your engine spec number. The parts list for your tractor includes the engine parts but you will not want to spend 270+ on a Kohler pump. Think about adding a low pressure electric pump. Share this post Link to post Share on other sites
953 nut 63,891 #3 Posted July 2, 2025 10 hours ago, whb100 said: Also think the little fuel pump is weak. You may want to start by checking the fuel tank for crud that could be blocking the fuel flow, replacing the rubber fuel line, and adding a new fuel filter. If you have been using gasoline with ethanol this could also be the source of fuel related problems. To find a gas station that sells real gas use this website. https://www.pure-gas.org/ Share this post Link to post Share on other sites
ri702bill 11,111 #4 Posted July 2, 2025 FYI - there are two different lever arm on the OE pumps if you go that route. Small block 7 & 8 HP have one style; the big blocks use a different one.... 1 Share this post Link to post Share on other sites
