Turt1e 5 #1 Posted June 30, 2025 Hey yall been redoing this old square fender and I’ve swapped it with a pred 212 I’m using the original push pull twist lock cable for the predator as I want to keep the dash plate looking stock the end of the cable is just a straight steel wire with a bend in so it would fit the original carb/gov anybody know anyways to make this work with a predator without having a butt load of slack thank you 2 Share this post Link to post Share on other sites
Achto 30,454 #2 Posted June 30, 2025 13 minutes ago, Turt1e said: anybody know anyways to make this work with a predator without having a butt load of slack thank you Pull the wire out of the cable, cut the outer cable to length, re-install the wire, cut it to length. Have to do this with any new cable that you buy in order to make it to size. 2 1 Share this post Link to post Share on other sites
Turt1e 5 #3 Posted June 30, 2025 22 minutes ago, Achto said: Pull the wire out of the cable, cut the outer cable to length, re-install the wire, cut it to length. Have to do this with any new cable that you buy in order to make it to size. Ohh they just make em long to fit any model I see thank you don’t why I didn’t think of that😂😂 1 1 1 Share this post Link to post Share on other sites
