Teddy da Bear62 120 #1 Posted June 29 (edited) I bought 3 NOS deck shells at auction a while back. I'm going to just make a nice useable deck for myself. All I need is to purchase new spindles. I'm going to buy a set from 8ten. Can anyone tell me the correct 8ten spindle that is equivalent to the original spindle found on wheel horse 48" deck? I'm guessing the deck is late 70's. No tag on it. Edited June 30 by Teddy da Bear62 1 Share this post Link to post Share on other sites
Lee1977 7,394 #2 Posted June 30 I have a 75-48MSO1 deck I have had Double DD, 3/4" keyed and it now has Metric spindles. They all fit and bolt up in the same holes. I have looked a the 8 ten spindles, looks like there isn't a double pulley, so you will have to get it some where else. I would buy the set for the 42" deck and speed the deck up a little. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,747 #3 Posted June 30 Here is a list of all the decks Mower DNA 48" side discharge 1966-1967 model RL-486 replaced by 1968 model 5-1481 1969 model 5-1482 1970 model 5-1483 1971 model 5-1200 1972 model 5-1201 1973 model 5-1202 1973-1974 model 5-1210 1975 model 5-1211 1976 model 65-48MS01 1976 model 65-48MS02 1977 model 75-48MS01 - These all used blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. ------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Note - 3/4" or .750" is 19.05mm 1977 model 75-48MS02 - Uses 6203 bearings with 3/4" ID - (First deck to use blades with 3/4" center hole) - Originally had a nylon-insert nut holding spindle pulley on. 1978 model 85-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1979 model 95-48MS00 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1979 model 95-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1980 model 05-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1981-1983 model 05-48MS02 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1984 model 05-48MS03 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. Note - 17mm is .669" 1985 model 05-48MS04 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers 1986-1988 model 05-48MS05 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers 1987-1988 model 05-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers 1989 model 15-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1990 model 15-48SC02 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1991-1992 model 15-48SC03 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1993-1997 model 78360 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1998-2007 and 2009-12 model 78361 - Uses 6203 bearings with 17mm ID - (These all use blades with 3/4" center hole) - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers Share this post Link to post Share on other sites
Teddy da Bear62 120 #4 Posted June 30 (edited) Wow! All the info fit to print but we're afraid to ask! It tells me all I want to know about the 48" deck makeup over the years. But not a cross reference to what 8ten has. Guess I will compare for myself. I have never understood the term "double d". Can you clarify it? Edited June 30 by Teddy da Bear62 Share this post Link to post Share on other sites
Lee1977 7,394 #5 Posted June 30 4 minutes ago, Teddy da Bear62 said: I have never understood the term "double d". Can you clarify it? The Double D is a 3/4" shaft with two sides flattened. Take a look a a brake shaft, they are still Double D. Share this post Link to post Share on other sites
kpinnc 15,718 #6 Posted June 30 37 minutes ago, Teddy da Bear62 said: have never understood the term "double d" Just Google... Oh no... don't do that. 1 4 Share this post Link to post Share on other sites
Teddy da Bear62 120 #7 Posted June 30 7 hours ago, kpinnc said: Just Google... Oh no... don't do that. Those "double D's" I completely understand....lol 1 Share this post Link to post Share on other sites
