Teddy da Bear62
Making up 48" deck
Teddy da Bear62
Posted (edited)
I bought 3 NOS deck shells at auction a while back.
I'm going to just make a nice useable deck for myself.
All I need is to purchase new spindles.
I'm going to buy a set from 8ten.
Can anyone tell me the correct 8ten spindle
that is equivalent to the original spindle found on wheel horse 48" deck?
I'm guessing the deck is late 70's.
No tag on it.
Edited by Teddy da Bear62
Lee1977
I have a 75-48MSO1 deck I have had Double DD, 3/4" keyed and it now has Metric spindles. They all fit and bolt up in the same holes.  I have looked a the 8 ten spindles, looks like there isn't a double pulley, so you will have to get it some where else. I would buy the set for the 42" deck and speed the deck up a little.
gwest_ca
Here is a list of all the decks
Mower DNA 48" side discharge
1966-1967 model RL-486 replaced by
1968 model 5-1481
1969 model 5-1482
1970 model 5-1483
1971 model 5-1200
1972 model 5-1201
1973 model 5-1202
1973-1974 model 5-1210
1975 model 5-1211
1976 model 65-48MS01
1976 model 65-48MS02
1977 model 75-48MS01 - These all used blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded.
Note - 3/4" or .750" is 19.05mm
1977 model 75-48MS02 - Uses 6203 bearings with 3/4" ID - (First deck to use blades with 3/4" center hole) - Originally had a nylon-insert nut holding spindle pulley on.
1978 model 85-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1979 model 95-48MS00 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1979 model 95-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1980 model 05-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1981-1983 model 05-48MS02 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1984 model 05-48MS03 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
Note - 17mm is .669"
1985 model 05-48MS04 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers
1986-1988 model 05-48MS05 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers
1987-1988 model 05-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers
1989 model 15-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1990 model 15-48SC02 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1991-1992 model 15-48SC03 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1993-1997 model 78360 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1998-2007 and 2009-12 model 78361 - Uses 6203 bearings with 17mm ID - (These all use blades with 3/4" center hole) - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
Teddy da Bear62
Posted (edited)
Wow!  All the info fit to print but we're afraid to ask!
It tells me all I want to know about the 48" deck makeup over the years.
But not a cross reference to what 8ten has.  Guess I will compare for myself.
I have never understood the term "double d".
Can you clarify it?
Lee1977
Can you clarify it?
The Double D is a 3/4" shaft with two sides flattened. Take a look a a brake shaft, they are still Double D.
kpinnc
Just Google... Oh no... don't do that. :lol:
  • Haha 4
Teddy da Bear62
Those "double D's" I completely understand....lol
  • Haha 1
