whb100 6 #1 Posted June 29, 2025 I'm having fun with my new to me 1977 B-100 with a 42" mowing deck. Really looking forward to learning more her. I've been mowing with it for about 3 months now. Runs better after changing the old rotten gas lines. She mows well enough but would benefit form a set of new blades. Any recommendations on where to get a set of 3 and possible part number? Thanks for any tips and information. 1 1 Share this post Link to post Share on other sites
parsonsponyz 420 #2 Posted June 29, 2025 Glad to have another new member to keep the interest alive. It would help to have a model number/deck size/discharge to get the correct blades. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #3 Posted June 29, 2025 Welcome to Red Square. Does the center holes of the blades have a 5/8" x 3/4" double-D center hole? The 1977 deck was the last year to use these unless the spindle assemblies were updated. The next deck has 3/4" center holes in the blades. You could have an older or newer deck than 1977. They all fit. Click on the fuzzy pictures in the links for more info. The first is rear discharge and the second side discharge. 2 Share this post Link to post Share on other sites
whb100 6 #4 Posted June 29, 2025 Thanks for the welcome. I'm not sure if it's an old style spindle hole or not. Haven't pulled them off yet. Numbers on the frame 10K801-15028. 7098 Deck is side discharge and numbers as best as I can make out are 5-42MS02-18133 7103 1 Share this post Link to post Share on other sites
whb100 6 #6 Posted June 29, 2025 gwest_ca, are you saying that the blades with the round spindle hole will work on both early and lat model decks? 1 Share this post Link to post Share on other sites
953 nut 70,655 #7 Posted June 29, 2025 Your deck takes the later model #106077 blade which is readily available. The manual below is for your mower deck. 1 1 Share this post Link to post Share on other sites
WHX?? 58,388 #8 Posted June 29, 2025 Check with KB Horse parts on the blades. https://www.wheelhorseforum.com/forum/177-kb-horse-parts/ Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #9 Posted June 30, 2025 2 hours ago, whb100 said: gwest_ca, are you saying that the blades with the round spindle hole will work on both early and lat model decks? No they will not work. Was just a way to help you identify the deck but you have the model number so not needed. 1 Share this post Link to post Share on other sites
whb100 6 #10 Posted June 30, 2025 Thanks for all the info guys. I'll do some ordering tomorrow. 1 Share this post Link to post Share on other sites
Achto 32,963 #11 Posted June 30, 2025 Looks like the gang has you covered. 2 Share this post Link to post Share on other sites
whb100 6 #12 Posted June 30, 2025 Sure do, thanks. 1 Share this post Link to post Share on other sites
Pullstart 71,561 #15 Posted June 30, 2025 Got any cool Share this post Link to post Share on other sites
whb100 6 #16 Posted June 30, 2025 Never posted a picture. I'll see if I can figure it out. Share this post Link to post Share on other sites
rjg854 13,454 #17 Posted June 30, 2025 2 hours ago, whb100 said: Never posted a picture. I'll see if I can figure it out. In the reply box, click on the choose files in red, below. Then go to your pictures and choose which ones you want to post. Once they load, click on the plus sign on the picture and you're all set. 1 Share this post Link to post Share on other sites
whb100 6 #18 Posted July 2, 2025 (edited) Preview attachment 20250123_152253.jpg [Image] 3.4 MB 2.webloc Pic test.Preview attachment 20250123_152253.jpg [Image] 3.4 MB 2.webloc Edited July 2, 2025 by whb100 Well that didn't work. Share this post Link to post Share on other sites
953 nut 70,655 #19 Posted July 2, 2025 Click on the choose files... on the device your photos are on and it will take you to your photos so you can select your photo. Share this post Link to post Share on other sites
