Sparky-(Admin) 23,284 #1 Posted June 27 Bought these 2 today.. C-81 and a 1973 10-8 speed. Neither run, not sure what I’ll do with em. Bought cheap and were only 5 miles from home. While I was there I spotted a 42” RD shell that was brand new. For another $20 that came home with me. Strange electric lift thingy on the 10 horse machine. Factory?? 4 4 Share this post Link to post Share on other sites
Sparky-(Admin) 23,284 #2 Posted June 27 Quick bath to get some of the funk off em. The K-181 rolls over by hand, the 10hp does not, hopefully it’s just packed with critter stuff. 4 6 Share this post Link to post Share on other sites
JCM 10,250 #4 Posted June 27 Much better looking when wet. 1 3 Share this post Link to post Share on other sites
Sparky-(Admin) 23,284 #5 Posted June 27 Once they dry off it’s back to ugly! I just don’t want to wench on em till at least some of the grime is gone. 3 2 Share this post Link to post Share on other sites
Sparky-(Admin) 23,284 #6 Posted June 27 14 minutes ago, gwest_ca said: Thanks Garry! A rare option? First one I’ve ever owned. 1 Share this post Link to post Share on other sites
ri702bill 9,534 #7 Posted June 27 So Mike - what ya figure on the C81??? I have a 875 roller that needs an engine and a few parts... Not impressed with the wiring on the 10 - wow. Bill Share this post Link to post Share on other sites
Sparky-(Admin) 23,284 #8 Posted June 27 24 minutes ago, ri702bill said: So Mike - what ya figure on the C81??? I have a 875 roller that needs an engine and a few parts... Not impressed with the wiring on the 10 - wow. Bill Other than a quick spray off I haven’t spent any time on either. Are you asking if the C-81 is for sale? Share this post Link to post Share on other sites
ri702bill 9,534 #9 Posted June 27 I guess I am..... Share this post Link to post Share on other sites
Sparky-(Admin) 23,284 #10 Posted June 27 17 minutes ago, ri702bill said: I guess I am..... I don’t plan to keep both, so most likely one or both will end up for sale. I need to spend a little time on each and determine the condition. I’m on business travel next week to California. When I get back I’ll see what’s up. You are officially first in line 3 Share this post Link to post Share on other sites
squonk 43,940 #11 Posted June 27 That big block 10 won't fit under the hood of the 875 without mods. 1 Share this post Link to post Share on other sites
ri702bill 9,534 #12 Posted June 27 1 hour ago, Sparky said: I don’t plan to keep both, so most likely one or both will end up for sale. I need to spend a little time on each and determine the condition. I’m on business travel next week to California. When I get back I’ll see what’s up. You are officially first in line Thanks... Bill Share this post Link to post Share on other sites
ebinmaine 72,993 #13 Posted June 27 3 hours ago, Sparky said: Thanks Garry! A rare option? First one I’ve ever owned. From what I understand that's pretty rare and definitely valuable. 3 Share this post Link to post Share on other sites
squonk 43,940 #14 Posted June 27 A short frame tractor needs the shallow pan and modified or special connecting rod for the big block to fit Share this post Link to post Share on other sites
Sparky-(Admin) 23,284 #15 Posted June 27 29 minutes ago, squonk said: A short frame tractor needs the shallow pan and modified or special connecting rod for the big block to fit I think he was talking about the K-181. I think it was short blocked at some point. I see gray paint. 2 Share this post Link to post Share on other sites
squonk 43,940 #16 Posted June 27 33 minutes ago, Sparky said: I think he was talking about the K-181. I think it was short blocked at some point. I see gray paint. Yup !y mistake. Looked at the pic of the Rat Motor. Yes that looks like a service engine. Share this post Link to post Share on other sites
JoeM 8,433 #17 Posted June 28 5 hours ago, JCM said: better looking when wet WV clear coat! I like those 8hp kohlers and don't know why. just like them. Sold them all but might end up with another sometime. Nice score on the deck shell sparks, give ya 60 for it at the show next year. 1 3 Share this post Link to post Share on other sites
ebinmaine 72,993 #18 Posted June 28 16 minutes ago, JoeM said: I like those 8hp kohlers and don't know why. just like them For the size they are absolute torque monsters. Run great. Start nice. Sip fuel. Excellent engines. 1 Share this post Link to post Share on other sites
kpinnc 14,713 #19 Posted June 28 7 hours ago, Sparky said: A rare option? First one I’ve ever owned. I think so, at least that model. Seen a bunch of the newer ones that go on Classic 300/400 series. I've only ever seen one of that type down here in NC. Very nice haul by the way. Whole lotta parts if nothing else. 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,541 #20 Posted June 28 Mike- i have a perfect candidate rd deck for you to swap everything over. Po cut a large piece of the Sheetmetal out but the rest is good. I also have a nice rd recycler insert too🤷 2 Share this post Link to post Share on other sites
Pullstart 67,042 #21 Posted June 28 12 hours ago, squonk said: That big block 10 won't fit under the hood of the 875 without mods. 12 hours ago, squonk said: A short frame tractor needs the shallow pan and modified or special connecting rod for the big block to fit But for reference… the steering arm just needed a little help to swing around the oil pan dipper on this shaker plate pan bolted to the frame… 1 Share this post Link to post Share on other sites
peter lena 9,309 #22 Posted June 28 @Sparky that deck looks sweet , perfect stage for a lubrication , SUN SOAK , found once you establish that on a deck , like this , you establish SALVATION , instead of rustafacation , my decks , hold little to no grass , like a 2 stage oil down , lighter chain and cable spray , for initial soal / creep base , then a heavier open gear spray , that bakes on with heat , combine that with a spindle upgrade rebuild , eliminate all original " grease " , do all related , bearings with lucas xtra hd , green , mule drive , pto lever start , improvement , been road testing that set up for years , no noise or failures , deck spin up is ridiculous , no squealing or whyining . just a suggestion , hot deck in the sun , pete Share this post Link to post Share on other sites
WHX?? 51,910 #23 Posted June 28 12 hours ago, JoeM said: I like those 8hp kohlers and don't know why. just like them. Like EB said because they pack a pretty good punch for the package??? Odd that I just had three 181's come through with a service block. They're all good runners too. Stevebo already beat me too it Sparky but I have a deck that somebody tried to convert to a SD. I actually stuck some new parts from KB in it but cut like a POS. Blew grass out every where but the SD. Yours if you want it just needs a new shell. Nice haul 1 Share this post Link to post Share on other sites
