BPEisenhower 553 #1 Posted June 26 So, I found out the hard way what going cheap does. Amazon fuel pump filled block with gas and back to tear down. Is there a suitable low pressure electric replacement? I've been told Facet is excellent but never ran one. Would I wire into key switch for power or hour meter? Don't want to use a toggle switch but would like an indicator light to show power to pump. How about a manual oil pressure gauge? Anyone run one? Share this post Link to post Share on other sites
pfrederi 18,972 #2 Posted June 26 I have used Facet Posi flow pumps for several years. made in USA. I use 4psi versions. I see no need for a light..you can here the pump clicking. Turn ignition switch to run When the sound changes the carb is full and you are ready to start. I use the I terminal on my K series that you do not have. You could use the Acc terminal. Would not pump while cranking but since the carb is full it will start ok. 1 1 Share this post Link to post Share on other sites
ebinmaine 74,582 #3 Posted June 26 These are the numbers that have been mentioned on this site. I keep them on a list. I personally use a Facet and recommend it. Facet 60245 or 60304. Mr. Gasket 42s. Carter P4070. 1 Share this post Link to post Share on other sites
Achto 29,872 #4 Posted June 26 Facet are good pumps, just wire it to the key switch. Easy enough to add a light if you wish but like stated above, you will hear it running when you turn the key on. 6 hours ago, BPEisenhower said: So, I found out the hard way what going cheap does. Amazon fuel pump filled block with gas and back to tear down. Did you run it with the gas in the oil? Might be able to get away with just an oil change. Share this post Link to post Share on other sites
BPEisenhower 553 #5 Posted June 26 I shut it down immediately when I saw the first puffs of white smoke. There was about a half gallon of gas mixed with oil. Hopefully, the rubber lines for remote oil filter aren't internally ruined. Expensive oil change considering I use Joe Gibbs racing oil 😤. Probably would have noticed sooner with oil pressure gauge Share this post Link to post Share on other sites
sjoemie himself 3,105 #6 Posted June 29 As said by the previous posters.. Facet pumps are good. We use them in tractors and heavy equipment all the time at the place where I work. Easy install and pretty robust. On a sidenote.. we use them in diesel equipment so that might be another type/number pump than the gas equivalent. 2 Share this post Link to post Share on other sites
jsoluna 215 #7 Posted August 14 (edited) I personally have used the 40177 Facet pumps for years. The lower PSI (1-2) ensures even marginal sealing float needle valves will not be overcome by the pump. I prefer them over the more common 4psi units. Even a pulse pump upgrade would be better than the knockoff mechanical. The Kohler OEM mechanical pumps are great, but after 35 years, they do have issues. The electric pumps make for easier starting, resist vapor lock, and with nothing connected to the crankcase, the risk of fuel saturation is all but eliminated. Edited August 14 by jsoluna 1 Share this post Link to post Share on other sites
