Turt1e 5 #1 Posted June 20, 2025 Hey yall recently acquired another wheel horse with a seized engine but everything else was good in shape. I’m looking to put a predator 212 in it just for the time being and to try it out. This isn’t a long term project lab as I plane in finding a kohler magnum or k301 to n the future. But does anyone know how or if any make bracket to use the existing bolt pattern to adapt to the predators bolt pattern. If I could have a blue print or if anyone makes them that would be great. 7A2E1184-DDD0-490C-AD56-FF1D45F97E86.mov Share this post Link to post Share on other sites
stvski80085 279 #2 Posted June 20, 2025 I would buy an adjustable mount and then drill the wholes where needed for the wheelhorse. Then you can go back to original at a later time. They are pretty cheap. Steve 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,753 #3 Posted June 20, 2025 Or w section sign post works great and lines up the shaft pretty much where it needs to go... I've done two that way... 2 Share this post Link to post Share on other sites
Turt1e 5 #4 Posted June 20, 2025 What size post did you use do you know? Share this post Link to post Share on other sites
slim67 2,825 #5 Posted June 20, 2025 26 minutes ago, Turt1e said: What size post did you use do you know? Unistrut works good too. Share this post Link to post Share on other sites
SylvanLakeWH 31,753 #6 Posted June 20, 2025 (edited) 1 hour ago, Turt1e said: What size post did you use do you know? 2" (Standard Stop Sign so I'm told...) Edited June 20, 2025 by SylvanLakeWH Share this post Link to post Share on other sites
Turt1e 5 #7 Posted June 21, 2025 1 hour ago, slim67 said: Unistrut works good too. I’d almost reckon that’s be better cuz then you got some play almost like an adjusted Hilary mount and then you could really fine tune your pulley position and tension. Definitely gonna see if it work the way I’d think it woud! Share this post Link to post Share on other sites
