Turt1e
Predator 212 mount
Turt1e
Hey yall recently acquired another wheel horse with a seized engine but everything else was good in shape. I’m looking to put a predator 212 in it just for the time being and to try it out. This isn’t a long term project lab as I plane in finding a kohler magnum or k301 to n the future. But does anyone know how or if any make bracket to use the existing bolt pattern to adapt to the predators bolt pattern. If I could have a blue print or if anyone makes them that would be great.
stvski80085
I would buy an adjustable mount and then drill the wholes where needed for the wheelhorse.  Then you can go back to original at a later time.  They are pretty cheap.
Steve
SylvanLakeWH
:text-yeahthat:
Or w section sign post works great and lines up the shaft pretty much where it needs to go... I've done two that way...
Turt1e
What size post did you use do you know?
slim67
Unistrut works good too.
SylvanLakeWH
Posted (edited)
2" (Standard Stop Sign :ph34r: so I'm told...)
Edited by SylvanLakeWH
Turt1e
I’d almost reckon that’s be better cuz then you got some play almost like an adjusted Hilary mount and then you could really fine tune your pulley position and tension. Definitely gonna see if it work the way I’d think it woud!
