dirtywaterdiver 2 #1 Posted June 15, 2025 So I have a manual, but it just covers basic operator maintenance. T have a belt puller break at the center and it has been replaced. However the PTO lever is WAY too stiff to engage. Do I need to reset the deck height and start at zero again. I got it from a friend so I don't really know where the previous owner had it set. What would be the "base zero" to begin sighting this in for proper use. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #2 Posted June 15, 2025 Hopefully this manual helps I do not know if this is the deck you have or not but the drive and hookup will be the same. Share this post Link to post Share on other sites
