nylyon-(Admin) 8,437 #1 Posted June 14 I have 2 almost identical tractors, 1995 416-8 and 1994 416-H. They have identical tires and both with 42” RD decks. The hydro steering is almost effortless, but the 8-speed takes some effort. Tires are inflated to 12 lbs on both, on the 8-speed I jacked up the front, removed the spindles cleaned and regreased, greased the fan gear and sprayed lithium grease in the flange bearing. Gotta be missing something, the 8-speed has to turn better. Thoughts / suggestions? 1 Share this post Link to post Share on other sites
ri702bill 10,264 #2 Posted June 14 There is a shim pack on the lower steering shaft between the fan gear and the lower steering block. The shim pack thickness sets the tooth engagement depth. Perhaps it is setting the engagement deeper than the other?? One way to "see" the engagement is to coat 4 or 5 of the fan gear teeth with fresh grease and turn the wheel to run it thru to the other side. Do both tractors. Do the squished out grease patterns look the same?? One deeper than the other?? 4 Share this post Link to post Share on other sites
nylyon-(Admin) 8,437 #3 Posted June 14 1 minute ago, ri702bill said: There is a shim pack on the lower steering shaft between the fan gear and the lower steering block. The shim pack thickness sets the tooth engagement depth. Perhaps it is setting the engagement deeper than the other?? One way to "see" the engagement is to coat 4 or 5 of the fan gear teeth with fresh grease and turn the wheel to run it thru to the other side. Do both tractors. Do the squished out grease patterns look the same?? One deeper than the other?? That is a good idea, I suspect to get to that area I need to take the dash apart, it’s really tight with the Onan in there. Share this post Link to post Share on other sites
Ed Kennell 43,327 #4 Posted June 14 I notice the same difference on my 300s. The 312H is much easier to steer than the 310-8. Share this post Link to post Share on other sites
ebinmaine 74,945 #5 Posted June 14 4 minutes ago, nylyon said: That is a good idea, I suspect to get to that area I need to take the dash apart, it’s really tight with the Onan in there. That may be a bottom of the tractor reach 2 Share this post Link to post Share on other sites
Handy Don 14,870 #6 Posted June 14 45 minutes ago, nylyon said: That is a good idea, I suspect to get to that area I need to take the dash apart, it’s really tight with the Onan in there. 41 minutes ago, ebinmaine said: That may be a bottom of the tractor reach Mostly something done from underneath but you may need to remove the battery to get at the locking collar on the upper steering shaft to let you lift that shaft a bit. At the other end, loosen the steering shaft pivot block and slide it rearward. Having a lift or other safe to be under work stand makes this a LOT easier. 1 Share this post Link to post Share on other sites
squonk 44,740 #7 Posted June 14 When you get things apart maybe you'll find the upper steering shaft bearing is the issue instead of the lower linkage. 5 Share this post Link to post Share on other sites
rmaynard 16,639 #8 Posted June 14 My 416-H steered fairly hard and aways felt like it was fighting me to stay straight. Then I checked and adjusted the toe-in. I found that a 1/8" toe-in can make all the difference. Just a thought. 5 Share this post Link to post Share on other sites
nylyon-(Admin) 8,437 #9 Posted June 14 21 minutes ago, Handy Don said: Having a lift or other safe to be under work stand makes this a LOT easier. My reputation precedes me 2 Share this post Link to post Share on other sites
nylyon-(Admin) 8,437 #10 Posted June 14 14 minutes ago, squonk said: When you get things apart maybe you'll find the upper steering shaft bearing is the issue instead of the lower linkage. I did lubricate that 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,437 #11 Posted June 14 1 minute ago, rmaynard said: My 416-H steered fairly hard and aways felt like it was fighting me to stay straight. Then I checked and adjusted the toe-in. I found that a 1/8" toe-in can make all the difference. Just a thought. This one seems to go straight, but will definitely check to see if I can adjust the toe a little. 2 Share this post Link to post Share on other sites
Lee1977 7,418 #12 Posted June 14 (edited) If someone tighten to gears too mich It will make it steer hard, 1" to 1 1/2" play steering is normal. The hole that uppper bushing is in wears and the steering wheel can move around I install the 6472 flange bearing up there Typical problem with my 300's. A nother problem is 2 ply tires ,unless you have them pumped up untill they round up in the center, they will fold up if you run over anything bigger then a match stick. Alinement and heims joints on the tie rods also helps with easer steering, Edited June 14 by Lee1977 1 Share this post Link to post Share on other sites
Handy Don 14,870 #13 Posted June 14 (edited) Our 312-H was a bear to steer. The smaller-statured operators in the family complained effectively so, to address the issue, we: thanked @ri702bill for milling the bottoms of the axles at the spindle holes to make them flat and shorten them to compensate for... spindle thrust bearing bearings like on the later 520’s while doing this we discovered that the arm on one of the spindles was bent so we re-aligned it then installed adjustable tie rods to tweak the toe-in checked and lubed all the steering mechanism (if there hadn’t already been a flange bearing at the forward end of the lower steering shaft, I’d have added one) It now steers and tracks very nicely according to all users! Edited June 14 by Handy Don 5 Share this post Link to post Share on other sites
ri702bill 10,264 #14 Posted June 14 3 hours ago, nylyon said: I found that a 1/8" toe-in can make all the difference. Just a thought. Needs just a bit mo' toe...... 1 Share this post Link to post Share on other sites
ri702bill 10,264 #15 Posted June 14 7 hours ago, nylyon said: but will definitely check to see if I can adjust the toe a little. To digress a tad off topic, but as a former Front End Technician.. I will. I saw a fantastic attempt to "correct" a severe toe-out condition on a NASCAR Racecar back in the day. Rusty Wallace was not only a good driver, but had excellent knowledge of the cars components and how each affected the overall handling. It was at Martinsville VA, I recall. Rusty was running third late in the race when he got collected in an accident that severely toed the left front out about 4 to 5 inches as the steering was bent. He radioed the pit crew to stage a pitstop, but as he approached, they all jumped back behind the wall when he came in at speed, spanked the inner wall hard and drove back onto the track. He did so as to not loose his third position in the field!!! "We'll change the tires next lap - that left front has served its purpose". His "adjustment" had re-bent the geometry back enough to make the car driveable to finish the race..... and not loose laps in the pits. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,902 #16 Posted June 14 16 minutes ago, ri702bill said: To digress a tad off topic, but as a former Front End Technician.. I will. I saw a fantastic attempt to "correct" a severe toe-out condition on a NASCAR Racecar back in the day. Rusty Wallace was not only a good driver, but had excellent knowledge of the cars components and how each affected the overall handling. It was at Martinsville VA, I recall. Rusty was running third late in the race when he got collected in an accident that severely toed the left front out about 4 to 5 inches as the steering was bent. He radioed the pit crew to stage a pitstop, but as he approached, they all jumped back behind the wall when he came in at speed, spanked the inner wall hard and drove back onto the track. He did so as to not loose his third position in the field!!! "We'll change the tires next lap - that left front has served its purpose". His "adjustment" had re-bent the geometry back enough to make the car driveable to finish the race..... and not loose laps in the pits. So youre suggesting Karl drive his 416-8 into a brick wall?? 5 Share this post Link to post Share on other sites
Handy Don 14,870 #17 Posted June 15 1 hour ago, Sparky said: So youre suggesting Karl drive his 416-8 into a brick wall?? Possibly suggesting that that tractor had been hit at some point in its life? @ri702bill surely recalls the bent arm on the tractor he worked on for us and who knows how that got there! 1 Share this post Link to post Share on other sites
ri702bill 10,264 #18 Posted June 15 9 hours ago, Handy Don said: Possibly suggesting that that tractor had been hit at some point in its life? @ri702bill surely recalls the bent arm on the tractor he worked on for us and who knows how that got there! It was Don that found the bent arm & fixed that. He mentioned that the way it was it went straight OK, but turning the spindle rotated out at a different end angle than the other when turned in the opposite direction (not to be confused with the Ackerman Angle designed into the tractor steering that moves the inside wheel at a tighter radius than the outer one in a tight turn). 10 hours ago, Sparky said: So youre suggesting Karl drive his 416-8 into a brick wall?? Only if he calls Rusty first... Share this post Link to post Share on other sites
