Red_Texan 4 #1 Posted June 13 All, I recently purchased the WH tiller and am working on getting it attached to the 310. My question is this; the tiller was taken off of a hyrdo WH so I purchased the SHORT clevis and straight conduit for my manual set up. Included with the tiller was the clevis lift cable. I am curious if the cables for the short and long clevis are different or if I can run the included cable with my new short clevis pin. I cannot test/trouble shoot yes because the parts are shipping out next week from WH parts and more. I would like to make changes to the order before it ships if possible. I have attached links to the exact parts I have purchased for reference. Thank you, B https://wheelhorsepartsandmore.com/product/toro-wheel-horse-lift-cable-clevis-108145-manual-transmission-short-clevis/ https://wheelhorsepartsandmore.com/product/toro-wheel-horse-lift-cable-tube-and-bracket-conduit-tube-manual-transmissions/ https://wheelhorsepartsandmore.com/product/toro-wheel-horse-hitch-104659-with-spring-assist-bracket-108485/ Share this post Link to post Share on other sites
peter lena 9,340 #2 Posted June 13 @ RED- TEXAN , like HITCH PIN CLIPS , on my rear frame levers , also push them all the way thru , to the last big hole ,? you won't loose them , that way , another thing with any cabling , I use chain and cable aerosol , makes any cable , more supple and retains lubrication to enhance slide and stop rust , NAPA has MACS , aerosol , pete Share this post Link to post Share on other sites
ineedanother 1,686 #3 Posted June 14 @Red_Texan I don't know that actually I understand your question or have the answer, but if you're asking about the length of cable, all 300 series have the same bell crank and probably use the same lift cable. I suspect that the difference in the length of clevis would make up for the difference between the straight and curved tubes. To be sure though, you might want to measure the length of the cable you have and call Lowell Monday and ask. He'll tell you what you need to hear. Share this post Link to post Share on other sites
Lee1977 7,295 #4 Posted June 14 (edited) The 300 400, and 500 series 8 speed tractors used the standard cable with the short clevis,. The long clevis is for Eaton Hydros and uses the same cable. Edited June 14 by Lee1977 3 Share this post Link to post Share on other sites
