markseven 93 #1 Posted June 10, 2025 My 8 horse Kohler on my garden tractor whenever I hook the fuel pump up to the carburetor like it getting too much fuel it floods and it runs poor it's like the needle is not seating correctly and I put new carburetor kits in it still wants to do it it runs real good when I bypass the fuel pump and just have gravity feed it runs pretty good what's going on. It starts much easier much quicker when the fuel pump is connected. These are original carter carbs I haven't tried a aftermarket one. Share this post Link to post Share on other sites
Achto 32,097 #2 Posted June 10, 2025 Check to make sure that this vent hole is clear. If it is not the fuel pump will force gas through the main jet instead of letting vacuum pull it through. It should vent to here. 3 1 Share this post Link to post Share on other sites
clueless 3,427 #3 Posted June 10, 2025 So if it runs good without the fuel pump, why did you put a fuel pump on it? Share this post Link to post Share on other sites
ri702bill 12,496 #4 Posted June 10, 2025 Welcome!! Electric fuel pump??? If the pressure is more than 4 PSI, it WILL blow fuel right by the seat in the carb.... Share this post Link to post Share on other sites
WHX?? 57,452 #5 Posted June 10, 2025 3 hours ago, markseven said: needle is not seating correctly and I put new carburetor kits in it Did you use a orginal Kohler carb kit? In the cheap after market kits the needle and seat do not work. Share this post Link to post Share on other sites
markseven 93 #6 Posted June 10, 2025 3 hours ago, clueless said: So if it runs good without the fuel pump, why did you put a fuel pump on it? It ran good once you've got it started Was hard to get started and you had to choke it a lot Share this post Link to post Share on other sites
markseven 93 #7 Posted June 10, 2025 3 hours ago, ri702bill said: Welcome!! Electric fuel pump??? If the pressure is more than 4 PSI, it WILL blow fuel right by the seat in the carb.... I know but why should it have more than 4 psi if everything is original. Share this post Link to post Share on other sites
markseven 93 #8 Posted June 10, 2025 1 hour ago, WHX?? said: Did you use a orginal Kohler carb kit? In the cheap after market kits the needle and seat do not work. I'm not sure exactly what I use for the carb kit the last time but I have a brand new kohler seat and needle I'm going to try next along with acto I think he's got a very good point too Share this post Link to post Share on other sites
clueless 3,427 #9 Posted June 10, 2025 48 minutes ago, markseven said: I know but why should it have more than 4 psi if everything is original. ?? Share this post Link to post Share on other sites
