TheMooseIsLoose 14 #1 Posted June 9, 2025 I cant find an original onan 146-6100 carb from onan or toro for my WH 516-H. I cant rebuild mine because of an air leak. Does anyone know of a replacement carb name & # that will fit/work. Thank you for your help. Share this post Link to post Share on other sites
lynnmor 8,384 #2 Posted June 9, 2025 Buy a used one on the big auction site, clean it out and check it over. Share this post Link to post Share on other sites
TheMooseIsLoose 14 #3 Posted June 9, 2025 7 minutes ago, lynnmor said: Buy a used one on the big auction site, clean it out and check it over. 7 minutes ago, lynnmor said: Buy a used one on the big auction site, clean it out and check it over. Share this post Link to post Share on other sites
TheMooseIsLoose 14 #4 Posted June 9, 2025 is there a link to this auction site Share this post Link to post Share on other sites
Achto 30,440 #5 Posted June 9, 2025 1 minute ago, TheMooseIsLoose said: is there a link to this auction site Here you go. https://www.ebay.com/ 1 Share this post Link to post Share on other sites
kpinnc 16,514 #6 Posted June 9, 2025 4 hours ago, TheMooseIsLoose said: because of an air leak. Have you verified the manifold isn't where the air leak is? It's a common problem on those two piece aluminum intakes. I always ran a little silicone sealant around the outer seam with my finger. Doesn't take much and easily removed if that isn't the problem. Share this post Link to post Share on other sites
nylyon-(Admin) 8,638 #7 Posted June 9, 2025 One of mine also had a leak between the manifold and intake port. Share this post Link to post Share on other sites
TheMooseIsLoose 14 #8 Posted June 9, 2025 Its not the manifold its the carb, i need to find a replacment Share this post Link to post Share on other sites
TheMooseIsLoose 14 #9 Posted June 10, 2025 Order a carb on Ebay, don't make any from toro or Onan for an 1988 so had to go with a China one. Didn't want to but not two many choices out there Share this post Link to post Share on other sites
lynnmor 8,384 #10 Posted June 10, 2025 2 minutes ago, TheMooseIsLoose said: Order a carb on Ebay, don't make any from toro or Onan for an 1988 so had to go with a China one. Didn't want to but not two many choices out there I saw plenty of used carbs on eBay. Share this post Link to post Share on other sites
TheMooseIsLoose 14 #11 Posted June 11, 2025 Dont know if i can trust used or new since you cant get OEM anymore but made the decision for new aftermarket. Will see how that turns out. Share this post Link to post Share on other sites
