23 Reo 235 #1 Posted June 4, 2025 (edited) I am replacing a very old outside oil filter gasket on my Onan P220. It's the gasket that is placed between the oil filter and the cooling tin. Do I just slide it on to the oil filter and push it until it rests on the tin? A picture would be very helpful. Edited June 4, 2025 by 23 Reo 1 Share this post Link to post Share on other sites
lynnmor 8,726 #2 Posted June 5, 2025 48 minutes ago, 23 Reo said: I am replacing a very old outside oil filter gasket on my Onan P220. It's the gasket that is placed between the oil filter and the cooling tin. Do I just slide it on to the oil filter and push it until it rests on the tin? A picture would be very helpful. You are correct. If you have an oil filter that is a bit small, it may not stay in place. I use only Onan 122-0800 or Fleetguard LF3339 filters. 1 1 1 Share this post Link to post Share on other sites
Ed Kennell 45,574 #3 Posted June 5, 2025 If your grommet is dry and cracked, replace it. If your filter is too small, wrap it with a layer of duct tape. 2 1 Share this post Link to post Share on other sites
kitkit 138 #4 Posted 6 hours ago i am having a problem with getting my gasket on the filter it , it is just too tight to get it on , it is a new to me tractor , it did not have one on it when i got it , not sure what is up ,is it possibe the wrong filter was used 1 Share this post Link to post Share on other sites
Ed Kennell 45,574 #5 Posted 5 hours ago 1 hour ago, kitkit said: ,is it possibe the wrong filter was used I guess it is possible, but I have never seen a filter that was too big. Did you try greasing and stretching the grommet? 1 Share this post Link to post Share on other sites
