23 Reo 242 #1 Posted June 4, 2025 (edited) I am replacing a very old outside oil filter gasket on my Onan P220. It's the gasket that is placed between the oil filter and the cooling tin. Do I just slide it on to the oil filter and push it until it rests on the tin? A picture would be very helpful. Edited June 4, 2025 by 23 Reo 1 Share this post Link to post Share on other sites
lynnmor 9,049 #2 Posted June 5, 2025 48 minutes ago, 23 Reo said: I am replacing a very old outside oil filter gasket on my Onan P220. It's the gasket that is placed between the oil filter and the cooling tin. Do I just slide it on to the oil filter and push it until it rests on the tin? A picture would be very helpful. You are correct. If you have an oil filter that is a bit small, it may not stay in place. I use only Onan 122-0800 or Fleetguard LF3339 filters. 1 2 1 Share this post Link to post Share on other sites
Ed Kennell 47,552 #3 Posted June 5, 2025 If your grommet is dry and cracked, replace it. If your filter is too small, wrap it with a layer of duct tape. 3 1 Share this post Link to post Share on other sites
kitkit 142 #4 Posted April 17 i am having a problem with getting my gasket on the filter it , it is just too tight to get it on , it is a new to me tractor , it did not have one on it when i got it , not sure what is up ,is it possibe the wrong filter was used 1 Share this post Link to post Share on other sites
Ed Kennell 47,552 #5 Posted April 17 1 hour ago, kitkit said: ,is it possibe the wrong filter was used I guess it is possible, but I have never seen a filter that was too big. Did you try greasing and stretching the grommet? 1 Share this post Link to post Share on other sites
sqrlgtr 4,077 #6 Posted April 17 here ya go just put this one on the other day. Be prepared for some sticker shock if you haven't purchased one yet. Share this post Link to post Share on other sites
kitkit 142 #7 Posted April 17 thank you , i agree about sticker shock 1 Share this post Link to post Share on other sites
kitkit 142 #9 Posted April 17 thanks everyone for the information. I tried soaking it into hot water putting it on. It was getting close but still wouldn't do it. I think I'll soak it in hot water and run the engine to where the filter is hot and see if that won't stretch it enough to get it on if not, I'm gonna send it back. It doesn't feel like rubbery. It feels more like a rubber vinyl composite or something that's kind of stiff maybe I got the wrong from a bad supplier 1 1 Share this post Link to post Share on other sites
sqrlgtr 4,077 #10 Posted April 17 2 hours ago, kitkit said: thanks everyone for the information. I tried soaking it into hot water putting it on. It was getting close but still wouldn't do it. I think I'll soak it in hot water and run the engine to where the filter is hot and see if that won't stretch it enough to get it on if not, I'm gonna send it back. It doesn't feel like rubbery. It feels more like a rubber vinyl composite or something that's kind of stiff maybe I got the wrong from a bad supplier The one I just put on in the picture above was pretty snug, but I got on without too much trouble. What brand oil filter are you using? 1 1 Share this post Link to post Share on other sites
lynnmor 9,049 #11 Posted April 17 3 hours ago, kitkit said: thanks everyone for the information. I tried soaking it into hot water putting it on. It was getting close but still wouldn't do it. I think I'll soak it in hot water and run the engine to where the filter is hot and see if that won't stretch it enough to get it on if not, I'm gonna send it back. It doesn't feel like rubbery. It feels more like a rubber vinyl composite or something that's kind of stiff maybe I got the wrong from a bad supplier Use a genuine Onan 122-0502 grommet and a Fleetguard LF3339 oil filter and report back. Never trust a previous owner to install the correct parts and choose quality. 2 1 Share this post Link to post Share on other sites
kitkit 142 #12 Posted April 18 i agree new tractor to me , know very little as to its previous care , i will try and get the correct stuff and see , thank you 1 Share this post Link to post Share on other sites
kitkit 142 #13 Posted April 18 i tried to get the gasket from onan/cummins but they showed out of stock as a couple other places did also , any suggestions as to where they might be available , thank you 1 Share this post Link to post Share on other sites
sqrlgtr 4,077 #14 Posted April 18 7 hours ago, kitkit said: i tried to get the gasket from onan/cummins but they showed out of stock as a couple other places did also , any suggestions as to where they might be available , thank you sent you a pm for a source on oil filter seal. 1 1 Share this post Link to post Share on other sites
kpinnc 19,002 #15 Posted April 19 With the filter installed, spray it and the grommet with windex. Spray as many times as needed until it's on. Windex will make both parts slick but evaporates and won't harm anything. Also works well for decals and bike grips... 3 Share this post Link to post Share on other sites
kitkit 142 #16 Posted April 19 (edited) when I do the oil change I will try this thank you Edited April 19 by kitkit Share this post Link to post Share on other sites
kitkit 142 #17 Posted April 19 (edited) Just now, kitkit said: Edited April 19 by kitkit Share this post Link to post Share on other sites
