23 Reo 229 #1 Posted June 4 (edited) I am replacing a very old outside oil filter gasket on my Onan P220. It's the gasket that is placed between the oil filter and the cooling tin. Do I just slide it on to the oil filter and push it until it rests on the tin? A picture would be very helpful. Edited June 4 by 23 Reo Share this post Link to post Share on other sites
lynnmor 7,788 #2 Posted June 5 48 minutes ago, 23 Reo said: I am replacing a very old outside oil filter gasket on my Onan P220. It's the gasket that is placed between the oil filter and the cooling tin. Do I just slide it on to the oil filter and push it until it rests on the tin? A picture would be very helpful. You are correct. If you have an oil filter that is a bit small, it may not stay in place. I use only Onan 122-0800 or Fleetguard LF3339 filters. 1 1 Share this post Link to post Share on other sites
Ed Kennell 41,776 #3 Posted June 5 If your grommet is dry and cracked, replace it. If your filter is too small, wrap it with a layer of duct tape. 1 1 Share this post Link to post Share on other sites
