edgcooper 19 #1 Posted June 1, 2025 Do any of you experts out there know how the momentary switch works and the proper orientation of wires to it. Traying to get the system working on my 418A. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,233 #2 Posted June 1, 2025 Does this diagram help? Click on the colored picture in the link to get it. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,233 #3 Posted June 1, 2025 Part number could be 111353 or 111346. Click on the picture for more and take the part numbers with you. The poor parts list we have does not tell us what models use what switch and the parts list is shared with 8hp, 10hp, 12hp, 14hp, 16hp and 18hp models. You may figure it out by the number of wires and colors. 1 1 Share this post Link to post Share on other sites
edgcooper 19 #4 Posted June 1, 2025 This should help because the wires were removed, and I had no idea what goes where. I assume the switch puts battery voltage to circuit board to test the bulbs ? Do I assume correctly? 1 Share this post Link to post Share on other sites
edgcooper 19 #5 Posted June 1, 2025 Does anyone know of a replacement switch for the 111353 which is not available anymore ? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,233 #6 Posted June 1, 2025 The switch description Momentary double pole single throw Like 2 switches in one (double pole) and a single action closes the 2 switches. Momentary is the switch returns to OFF on it's own. This could be a toggle or push button style. Check with one of our venders for a used switch. (Double throw switch has ON-OFF-ON toggle positions) 1 Share this post Link to post Share on other sites
953 nut 66,058 #7 Posted June 1, 2025 5 hours ago, edgcooper said: I assume the switch puts battery voltage to circuit board to test the bulbs ? Do I assume correctly? Not quite, some of the lights have 12 volts supplied to them and are seeking a ground which is provided by the test switch. Others have a ground provided and are seeking 12 volts to operate. That is why it is a Double Pole switch. Call Lincoln at A to Z Tractor, he probably would have a good used one https://www.a-ztractor.com/ You can check with K&B, they have all kinds of NOS parts. https://www.wheelhorseforum.com/classifieds/vendors/kb-wheelhorse-parts/ 1 Share this post Link to post Share on other sites
edgcooper 19 #8 Posted June 2, 2025 Thanks for all the info. I better understand the operation and get wires back to proper locations. 1 Share this post Link to post Share on other sites
