Horse Newbie 7,395 #1 Posted May 31 When I engage the PTO the engine Boggs down. WOT or idling… makes no difference. No PTO belt, deck, or load on PTO. Where do I need to look first ? PTO bearing ? The bearing does seem a little noisy. But would that bog it down with no load ? Share this post Link to post Share on other sites
wallfish 18,149 #2 Posted May 31 Pull that pulley bell off the shaft and take a look inside there. It comes off pretty easily 2 Share this post Link to post Share on other sites
squonk 43,843 #3 Posted May 31 The outer bearing goes bad a lot. Easy to change. #204RR6 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,493 #4 Posted May 31 You have a thrust bearing between the transmission drive pulley and the engine block also. 3 Share this post Link to post Share on other sites
Horse Newbie 7,395 #5 Posted May 31 2 hours ago, wallfish said: Pull that pulley bell off the shaft and take a look inside there. It comes off pretty easily 2 hours ago, squonk said: The outer bearing goes bad a lot. Easy to change. #204RR6 23 minutes ago, gwest_ca said: You have a thrust bearing between the transmission drive pulley and the engine block also. Hey fella’s This is a parade tractor at the minute. Wanting to bring to The Big Show(featured tractor this year). I am hesitant about more wrenching on it between now and the show. I don’t want to tear something down and then not have it done in time. Is those bearings probably okay until after the show ? Share this post Link to post Share on other sites
Sparky-(Admin) 23,169 #6 Posted May 31 15 minutes ago, Horse Newbie said: Hey fella’s This is a parade tractor at the minute. Wanting to bring to The Big Show(featured tractor this year). I am hesitant about more wrenching on it between now and the show. I don’t want to tear something down and then not have it done in time. Is those bearings probably okay until after the show ? I would think it would be fine since you won’t be engaging the PTO for cruising around. 1 Share this post Link to post Share on other sites
Horse Newbie 7,395 #7 Posted May 31 51 minutes ago, gwest_ca said: You have a thrust bearing between the transmission drive pulley and the engine block also. So if that thrust bearing is not turning as free as it should, and I engage the PTO, then the less than free rotating bearing could be a load source ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,493 #8 Posted May 31 14 minutes ago, Horse Newbie said: So if that thrust bearing is not turning as free as it should, and I engage the PTO, then the less than free rotating bearing could be a load source ? I would say so. 1 Share this post Link to post Share on other sites
Ed Kennell 42,055 #9 Posted May 31 27 minutes ago, Horse Newbie said: So if that thrust bearing is not turning as free as it should, and I engage the PTO, then the less than free rotating bearing could be a load source ? If that bearing is bad enough to bog down the engine, it should get hot real quick. 4 Share this post Link to post Share on other sites
Bill D 2,256 #10 Posted May 31 (edited) 3 hours ago, gwest_ca said: You have a thrust bearing between the transmission drive pulley and the engine block also. I have a GT1642 and a GT1800. Neither one has a thrust bearing. Here's a picture of the GT1800. Verify if you have a thrust bearing. If not, my money's on the PTO bearing. Edited May 31 by Bill D 2 Share this post Link to post Share on other sites
8ntruck 7,842 #11 Posted June 1 Could be that the short shaft that goes through the pto pulley is contacting the end of the crankshaft. The stub shaft does not turn, but the crank is turning. Good luck. Please post what you find and what you did to fix it. 1 Share this post Link to post Share on other sites
cleat 7,260 #12 Posted June 1 2 hours ago, Bill D said: I have a GT1642 and a GT1800. Neither one has a thrust bearing. Here's a picture of the GT1800. Verify if you have a thrust bearing. If not, my money's on the PTO bearing. Only the Briggs single cyl has the thrust bearing. However, as seen in the above picture, the main pulley does sit close to the engine block. Make sure you have clearance there and that the pulley is tight on the crankshaft and is not getting pushed into the engine block as the PTO is engaged. If you engage the PTO with the engine off you can also verify that the engine can turn over easily by hand (by rotating the PTO pulley). If the engine turns easily by hand then maybe there is a safety switch issue. 2 1 Share this post Link to post Share on other sites
Bill D 2,256 #13 Posted June 1 (edited) 3 hours ago, cleat said: Only the Briggs single cyl has the thrust bearing. However, as seen in the above picture, the main pulley does sit close to the engine block. Make sure you have clearance there and that the pulley is tight on the crankshaft and is not getting pushed into the engine block as the PTO is engaged. If you engage the PTO with the engine off you can also verify that the engine can turn over easily by hand (by rotating the PTO pulley). If the engine turns easily by hand then maybe there is a safety switch issue. According to Gary's TSB there are some early models that had external thrust bearings. I have a hydro pulley from a C161 that is machined for that external thrust bearing. Apparently the early Briggs twins did not have ball bearing supported crankshafts. Edited June 1 by Bill D Additional clarity 2 Share this post Link to post Share on other sites
kpinnc 14,652 #14 Posted June 1 6 hours ago, Horse Newbie said: Is those bearings probably okay until after the show ? If it is the end bearing, I have a couple PTO bells you can try when you get the engines for Bill. 2 Share this post Link to post Share on other sites
Horse Newbie 7,395 #15 Posted June 1 1 hour ago, 8ntruck said: Good luck. Please post what you find and what you did to fix it. Will do. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,493 #16 Posted June 1 Have never seen either but found this in an original parts list 2 1 Share this post Link to post Share on other sites
Bill D 2,256 #17 Posted June 1 6 hours ago, gwest_ca said: Have never seen either but found this in an original parts list I have actually seen both. A neighbor has a GT100 that I service. I recently picked up a C161 8 speed for its engine. Someone had swapped an 1997 18 HP Briggs into it. All of the original thrust bearing pieces were swapped as well. Only time I've seen that on a twin. 1 Share this post Link to post Share on other sites
Lee1977 7,215 #18 Posted June 1 (edited) It could be the thrust bearing as the PTO puts pressure on it when the PTO is engaged. Edited June 1 by Lee1977 1 Share this post Link to post Share on other sites
ineedanother 1,668 #19 Posted June 1 If you can measure temps, I think it might show where the friction is. 2 Share this post Link to post Share on other sites
peter lena 9,280 #21 Posted June 3 @Horse Newbiehttps://factorysupplyoutlet.com/timken-204rr6-a4363/?cmp_id=22546029312&adg_id=178229256446&kwd=&device=c&gad_source=1&gad_campaignid=22546029312&gbraid=0AAAAAC4SZ_--pPhiH3x_FnG4yUdY1IFH2&gclid=Cj0KCQjwuvrBBhDcARIsAKRrkjeyVSjVl9f5f75-S7B3LvHco7Izxk0E65X0q9FBE_HdvBJJVvrIVvgaAhrsEALw_wcB wide rubber side shields , for a clean out and regreasing , bearing gets very hot / load stress failure , like lucas 550 deg flash point , polyurea rated , green chassis grease , never had a load failure , or noisy whine, all my spindles , mule drive , pto related , all re greased , drive belt spins / drives very easily , pete 1 Share this post Link to post Share on other sites
Bill D 2,256 #22 Posted June 3 The PTO thrust bearing is 109842. All over online. 1 Share this post Link to post Share on other sites
Horse Newbie 7,395 #23 Posted June 3 2 hours ago, Bill D said: Any updates? Not yet. As I said, this is currently just used for cruising the strip and impressing the chicks. I will investigate more when I get home from The Big Show and report back. 1 Share this post Link to post Share on other sites
Horse Newbie 7,395 #24 Posted June 3 Just now, Horse Newbie said: Not yet. As I said, this is currently just used for cruising the strip and impressing the chicks. I will investigate more when I get home from The Big Show and report back. Share this post Link to post Share on other sites
Horse Newbie 7,395 #25 Posted June 3 2 minutes ago, Horse Newbie said: Cruising the strip and impressing the chicks… 2 Share this post Link to post Share on other sites
