Easton Rich 1,249 #1 Posted May 31, 2025 I just finished my B-80 and there is now slapping/knocking sound coming from the upper part of the cylinder. Just what need right when I finish it. Any help or advice is greatly appreciated! 2 Share this post Link to post Share on other sites
oliver2-44 11,515 #2 Posted May 31, 2025 (edited) What was done to the engine? Hone and rering? Bored oversized? Crank ground and undersize rod? Valve guides replaced. Valves clearance set by grinding stems? Edited May 31, 2025 by oliver2-44 1 Share this post Link to post Share on other sites
Easton Rich 1,249 #3 Posted May 31, 2025 Nope. Completely stock. Never touched it internally. It ran fine and I didn’t wanna change that. 1 2 Share this post Link to post Share on other sites
ri702bill 12,230 #4 Posted May 31, 2025 Time to invest in a head gasket. Remove the head, noting the overall condition of the gasket seal - is it completely sealed?? Time to measure the cylinder bore and write down the results. this requires telescopeing bore gages and a good dial caliper. with the piston at the bottom of its stroke, measure the bore in 6 places: top(where the rings hit, not the very top), middle, and bottom at 90 degrees. That would be parallel and perpendicular to the crank ends. Compare readings. Compare both the bore size and deviations to the allowable limits in the Kohler manual. If ir looks questionable, time to remove the piston to measure it the same way. The piston wears on the thrust side - if excessively worn, that causes the slapping noise as it wiggles its way up & down.... 1 Share this post Link to post Share on other sites
kpinnc 18,388 #5 Posted May 31, 2025 I gotta do the same on my son's Ranger. It has developed a "one per rev" knock from outta nowhere. Ran like a top before... 1 Share this post Link to post Share on other sites
953 nut 66,551 #6 Posted May 31, 2025 Get out the timing light or do static timing on the engine, it could be ignition timing is causing the knock. 6 Share this post Link to post Share on other sites
Easton Rich 1,249 #7 Posted June 1, 2025 17 hours ago, kpinnc said: I gotta do the same on my son's Ranger. It has developed a "one per rev" knock from outta nowhere. Ran like a top before... Welp at least I’m not in this alone 1 1 Share this post Link to post Share on other sites
Easton Rich 1,249 #8 Posted June 1, 2025 I’ll check that before i tear it down 13 hours ago, 953 nut said: Get out the timing light or do static timing on the engine, it could be ignition timing is causing the knock. 2 Share this post Link to post Share on other sites
clueless 3,403 #9 Posted June 1, 2025 I'm confused, you said it ran fine but now it's not, what was done prior to the noise? 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #10 Posted June 2, 2025 Was the piston put back in the same orientation it came out? Share this post Link to post Share on other sites
Easton Rich 1,249 #11 Posted June 2, 2025 10 hours ago, clueless said: I'm confused, you said it ran fine but now it's not, what was done prior to the noise? Nothing Share this post Link to post Share on other sites
Easton Rich 1,249 #12 Posted June 2, 2025 It’s a Kohler replacement short block Share this post Link to post Share on other sites
RED-Z06 2,718 #13 Posted June 2, 2025 So the engine was not disassembled during the refresh? Was the sheetmetal removed? The head? Carb? Share this post Link to post Share on other sites
Easton Rich 1,249 #14 Posted June 2, 2025 17 hours ago, RED-Z06 said: So the engine was not disassembled during the refresh? Was the sheetmetal removed? The head? Carb? Nope. I removed the carb, fuel pump and sheet metal, that’s all. It’s very strange. I’ve checked oil, I just changed it a week ago. Share this post Link to post Share on other sites
RED-Z06 2,718 #15 Posted June 2, 2025 1 minute ago, Easton Rich said: Nope. I removed the carb, fuel pump and sheet metal, that’s all. It’s very strange. I’ve checked oil, I just changed it a week ago. Sheetmetal bolt rubbing the flywheel? Maybe something went down the intake and is firmly forged into the piston crown? Share this post Link to post Share on other sites
Easton Rich 1,249 #16 Posted June 2, 2025 I will definitely tear it down. If it is pretty badly damaged I will replace it with a 10-14hp Kohler. I will for sure keep this one and rebuild it, but I hope it doesn’t come to that😬 Share this post Link to post Share on other sites
squonk 46,835 #17 Posted June 2, 2025 2 hours ago, RED-Z06 said: Sheetmetal bolt rubbing the flywheel? Yes. Putting too long a bolt in the shroud can do this. Share this post Link to post Share on other sites
RED-Z06 2,718 #18 Posted June 2, 2025 31 minutes ago, squonk said: Yes. Putting too long a bolt in the shroud can do this. Been there done that. On my K181 its tight quarters to the battery box so i put a 1/4-20 stud in that hole, slotted the cover. The bolt was touching the flywheel and i spent an hour trying to figure out why it only did it with the shroud on 1 Share this post Link to post Share on other sites
Easton Rich 1,249 #19 Posted June 3, 2025 I’ll check it out!! Share this post Link to post Share on other sites
