chev0545 237 #1 Posted May 28, 2025 314-h the trans lever started shaking i took it apart the drive belt has alot of chunks out of it.does the small pulley have a bearing (it sounds a little rough) how do you take off thanks 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,981 #2 Posted May 28, 2025 Looks fairly simple https://www.partstree.com/models/73401-314-h-toro-garden-tractor-sn-059000001-059000260-1995/clutch-brake-motion-control-linkage-8/ 1 Share this post Link to post Share on other sites
953 nut 63,966 #3 Posted May 28, 2025 The idler pulley is held in place with a 3/8 bolt, use a 9/16" wrench to remove it. If you have doubts about your ability to remember where everything goes take several pictures as you go along. 1 1 Share this post Link to post Share on other sites
chev0545 237 #4 Posted May 29, 2025 so there is no nut behind it 1 Share this post Link to post Share on other sites
oldlineman 1,633 #5 Posted May 29, 2025 Should have a lock nut I believe. Share this post Link to post Share on other sites
