S416-8 388 #1 Posted May 28 I just added the 3-point hitch setup to the 180 I am working on. The hydo on the 3-point is weak lifting (can only lift me and that is slow) and the deck doesn't move at all. I did change the valve body from the 200 but only the push line on the deck has good pressure. the others flow but it is slow.. is there a purge on the hydro to pull any air out of the system ? Any other ideas that I should check ? Deck worked great with the old valve body.. thanks Share this post Link to post Share on other sites
pfrederi 18,644 #2 Posted May 28 As far as I know the D180 and D 200 are the same. Did the valve work on the D200??? I have had the D200 hydro apart and never had a problem getting her to work afterward No need to bleed anything just work the cylinders a few times... Have you done a pressure test on the charge pump??? Share this post Link to post Share on other sites
S416-8 388 #3 Posted May 28 Thanks and never tested a charge pump.. regarding the 200 valve - not sure I bought it no running for the 3 point and rear PTO and then as tome allows to rebuild it. The pump for the 180 worked great before I swapped valves but will be putting that valve back in after moving the handle for the 3-point over to it.. more tonight 1 Share this post Link to post Share on other sites
S416-8 388 #4 Posted May 29 GM and fixed the hydro.. bad spring and a semi plugged channel. I may be interested in the rear finish mower that you have listed. What is the best you would do on it? thanks Share this post Link to post Share on other sites
