S416-8
D180 Hydro weak
S416-8
I just added the 3-point hitch setup to the 180 I am working on. The hydo on the 3-point is weak lifting (can only lift me and that is slow) and the deck doesn't move at all. I did change the valve body from the 200 but only the push line on the deck has good pressure. the others flow but it is slow.. is there a purge on the hydro to pull any air out of the system ? Any other ideas that I should check ? Deck worked great with the old valve body.. thanks
pfrederi
As far as I know the D180 and D 200 are the same.  Did the valve work on the D200???  I have had the D200 hydro apart and never had a problem getting her to work afterward No need to bleed anything just work the cylinders a few times...  Have you done a pressure test on the charge pump???
S416-8
Thanks and never tested a charge pump.. regarding the 200 valve - not sure I bought it no running for the 3 point and rear PTO and then as tome allows to rebuild it. The pump for the 180 worked great before I swapped valves but will be putting that valve back in after moving the handle for the 3-point over to it.. more tonight
S416-8
GM and fixed the hydro.. bad spring and a semi plugged channel.
I may be interested in the rear finish mower that you have listed. What is the best you would do on it? thanks
