Treepep 1,151 #1 Posted May 27, 2025 Hey guys and gals. Wondering if anyone knows the snap ring size on a C 120 spinde shaft? Many thanks in advance 1 Share this post Link to post Share on other sites
pfrederi 21,151 #2 Posted May 27, 2025 What model deck 36" 42 SD RD 48SD Wheel horse changed spindle design over the years 1 Share this post Link to post Share on other sites
Treepep 1,151 #3 Posted May 27, 2025 Sorry. Steering spindle c clip/snap ring 1 Share this post Link to post Share on other sites
ri702bill 13,068 #5 Posted May 27, 2025 3/4 inch... the grooves for E-rings and full circle snap rings are not the same.... 2 Share this post Link to post Share on other sites
Treepep 1,151 #6 Posted May 27, 2025 5 minutes ago, ri702bill said: 3/4 inch... the grooves for E-rings and full circle snap rings are not the same.... I don't fully understand this sir. Can you elaborate. Wondering if that is why the ring I put on did not stay put?? 1 Share this post Link to post Share on other sites
ri702bill 13,068 #7 Posted May 27, 2025 The 2 grooves have different inner diameters and width. An E ring that is sprung open will not seat and could fall off. It can be closed a bit with pliers. Once it is installed it should not be able to spin in the groove freely... same goes for the full circle type. 4 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #8 Posted May 28, 2025 When snap rings and E-rings are made they are stamped so one side has rounded edges and the other side has sharp edges. This one should be installed with the round side down and the sharp edge up. Harder for the ring to jump the groove when pressure is applied. 4 Share this post Link to post Share on other sites
peter lena 10,065 #10 Posted May 28, 2025 @Treepep , also like the black vinyl push on cover , for upper spindle protection , pete 2 Share this post Link to post Share on other sites
