JoeB 34 #1 Posted May 27 So i bought a bulb to pump gas before starting and am about to install. Just one question. I have a gas filter in the middle if the fuel line. Should i out the bulb between the filter and the carb or between the filter and the tank or does it matter? Thanks un advance for your advice joe Share this post Link to post Share on other sites
oliver2-44 10,678 #2 Posted May 27 Put the bulb between the tank and the filter. That way the bulb does not have to work as hard trying to suck gas through the filter. 3 Share this post Link to post Share on other sites
clueless 3,222 #3 Posted May 27 3 minutes ago, oliver2-44 said: Put the bulb between the tank and the filter. That way the bulb does not have to work as hard trying to suck gas through the filter. Share this post Link to post Share on other sites
Ed Kennell 41,771 #4 Posted May 27 13 minutes ago, oliver2-44 said: Put the bulb between the tank and the filter. And the filter picks up any dirt stirred up by the installation of the primer bulb. 1 Share this post Link to post Share on other sites
