jerryb131313 4 #1 Posted May 24, 2025 can someone tell me what belts fit on a wh 414-8 deck#0548ms05 &tractor #m14s601s40 year 1988? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,981 #2 Posted May 24, 2025 Welcome to Red Square Click on the fuzzy picture. The belts are listed on the page that comes up The 1988 414-8 tractor model number is 31-14K803 The engine used is Kohler M14S-601540 2 Share this post Link to post Share on other sites
953 nut 63,982 #5 Posted May 25, 2025 Many of us use the Kevlar belts from Tractor Supply with good results. 4 1 Share this post Link to post Share on other sites
Ed Kennell 44,667 #6 Posted May 25, 2025 9 hours ago, 953 nut said: Many of us use the Kevlar belts from Tractor Supply with good results. Around $26 for a 1/2 X 107 3 Share this post Link to post Share on other sites
peter lena 9,716 #7 Posted May 25, 2025 @jerryb131313 would suggest that you look at , every rotational related part , unless every movement part , slides / spins , functions without screaming , rough , obvious effort , the total combination of that belt loading is what you are dealing with , often refer to my decks easily moving , by hand at the pto mule drive down to deck area belt access , the easier that belt engagement moves the deck spindle assembles , the better it is , 12 related bearing points , this is a gold mine correction area , once done , it works as it should , pete Share this post Link to post Share on other sites
jerryb131313 4 #8 Posted May 27, 2025 On 5/24/2025 at 5:17 PM, Ed Kennell said: to the would like to thank everyone for the great info saved me alot of time. again thank you all may God bless... 1 2 Share this post Link to post Share on other sites
